Results 1 to 5 of 5
    Reputation: Phierce's Avatar
    New XT 775 vs Saint 800
    Looks like the calipers are the same and the only difference is the levers.
    Am I right???
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the 800 calipers are the same as the previous generation XT (760s)...the 770s have a marginally bigger piston and use an inline (0 degree) connector instead of the 90 deg. banjo used on the 800 and 760.
    Is there a big difference between the xt 770 and saint (xt760) levers?
    I currently have XT770s calipers with saint levers and goodridge lines on 203mm rotors and I need more braking power for the front. I maybe thought of getting a new front lever assembly with xt 770 specs
    Quote Originally Posted by jetpilot
    the servowave should help a tiny bit..but I don't think it will be that big of a change.....have you tried different pad compounds?
    I have goodridge pads, dont know which compund really.
    I get turkey wabble on the front and uneven brake force at different degrees of the disc with the same lever actuation. The disc is not bent and I sanded both pads and disc
