Results 1 to 3 of 3
    Reputation: Volsfan's Avatar
    Dec 2005
    New Hub - Centerlock or 6 Bolt
    I am having a new wheel built. The rotor I am using is a ISO 6 bolt. I have a DT Swiss adaptor already.
    So, do I go centerlock or 6 bolt.
    What are the pros and cons of each?
    Thanks for the help.
    It's not the falling that hurts, it is the sudden stop at the bottom!
    Meh.
    Reputation: XSL_WiLL's Avatar
    Centerlock is quick and easy to remove.
    6 bolt has a broader range of adjustment (use of spacers between the rotor and the hub).
    My favorite hubs only come in 6 bolt.
    Some argue that there are weight savings to be had.
    Jul 2003
    As Will said...
    all of my favorite hubs only come in 6 bolt. But if you want the versatility to go either way, then go with the centerlock hub and use the adaptor if you are currently using 6 bolt rotors. If you don't ever plan on using brakes that use a centerlock then it's pretty much a waste of time. But if there might be a Shimano centerlock brake set in your future then it'd be worth it I suppose.
    Good Dirt
