Results 1 to 11 of 11
    Reputation: MATPHAT's Avatar
    New front Rotor for my BB7s?
    Looking to replace the stock rotor that came with my BB7s.
    Staring at the G3 Cleansweep, but I think that's just the newer version of the one that comes stock.
    Anyone have any suggestions for a nice 180mm replacement that doesn't warble like a damn turkey?
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    The new HS1 rotors are pretty nice and the weight is low too.
    Too, set-up with the BB7 is most of the noise battle.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    LightJunction.com
    Reputation: lightjunction's Avatar
    I'm using G3s with BB7s one one of my bikes. It's a little noisy, but overall performance is good.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    Reputation: Restricted's Avatar
    I think you need the G2 for the BB7. As the G3 has smaller a smaller surface area for pad contact.
    Somebody explains it here.... Physics Buffs: Getting every drop out of your BB7's
    LightJunction.com
    Interesting. That would definitely explain the noise. To the bike cave...
    "The new HS1 rotors are pretty nice and the weight is low too."
    You may want to avoid using the HS1, and the G3 for that matter, with the BB7. Both have smaller brake tracks than the G2. I tried using a 180mm HS1 with the BB7. The outer edge of the brake pad aligned perfectly with the outer diameter of the HS1 braking surface, but the inner edge of the brake pad overhung the inner diameter of the braking surface. This caused the brake pads to contact the spokes on the rotor and generate a pulsation that could be felt when braking. Also caused an uneven wear pattern along the inner edged of the brake pad.
    Huckin' trails
    Reputation: David C's Avatar
    Hell, even the stock 203mm G2 that came with my BB7 has the pad wearing down more then 1/8 on the rotor spider arms. Plus that G2 was warping like crazy and won't stay quiet... Good thing my bike came stock with the old style Hayes V8 rotors. Wide braking surface, silent and are very hard to warp compared to the G2. You may still be able to find some online. I didn't try the new version with the new cut-outs. They looks very similar to the G2 now.
    Next I'll probably try some 140mm HS1 with BB7 rear. We'll see.
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    B A N N E D
    Quote Originally Posted by David C View Post
    Where was the outer edge of the pad in relation to the outer edge of the rotor ?
    If it was 1/8" or more in from the outer edge of the rotor, the caliper might of needed packing out a bit with some washers.
    I had a old hayes brake that squealed like a banshee, I noticed that the pads weren't lining up with the rotors braking track as they should and the pads were overhanging the inner edge of the braking track. I packed the caliper out on the adapter with some washers till the pads lined up with the braking track as they should, the noise went away and the brake worked much better.
    MTB B'dos
    Reputation: LyNx's Avatar
    BB7s and Juicys use the same pad and from my experience I'd never use a G3 rotor. Guy gave me some brakes a bit back with a G3 floating rotor, so I put it on of course cause it should work better, well no, damn thing was so noisy and didn't work much better. Bit of advice, if you're going to buy a new G2 rotor, I'd advise you consider buying an entire BB7 caliper with the size rotor you want, it will only cost you about $15-20 more and you'll have a backup caliper and spare pads.
    I have run the Cleansweep X 160 front 140 rear since they hit the market. Yes, the pads overlap, but the performance has been better than the Roundagon, G2, and G3. The 140 rear has stayed perfectly true and has not made any noise. The 160 in the front came from the factory with a little bend in it and I have had to true it twice. It is starting to warble. I am going to try the Hope floating rotors next.
    Reputation: akacoke's Avatar
    clean sweeps are kinda noise. id just get the new HS1 . its pretty quite.
    17 Lynskey Fatskey
    07 Kona Stab
    14 Specialized Fatboy
    04 Santa Cruz V10
    My Parts for sale link
