Results 1 to 7 of 7
    Sep 2004
    new brake pads for Hardrock comp, help?
    Hello everyone, I have a question for my Hardrock Comp. It came with these cheap Tektro IO disc brakes, and I'd like to replace the pads with aftermarket ones in hopes of improved braking power. Does anyone know what companies make replacement pads for these brakes? I've searched around and I can barely find info. on the brakes themselves let alone the pads. Thanks!
    There are a few things you can try.
    -Koolstop makes some of the best pads I've tried, and I'm generally partial to the dual compound. Making sure your rims are generally clean is also a good idea, because a dusty rim doesn't brake as well as a clean one, except on ceramic rims. (Which you don't have, so don't worry about it.)
    -Make sure you understand how to properly align brake pads, because that will make a world of difference.
    -Understand that OEM brakes are OK, but there are some far superior aftermarket brkes that will really wow you.
    -I'm hoping you understand about how and why the front brake is more powerful than the rear brake. Because it is.
    -Look into brake boosters if you're on a budget, and don't want to go as far as new brakes. They look funny at first, but they can work wonders sometimes.
    galferusa
    galfer replacements
    Quote Originally Posted by leemr2
    Very often with Taiwanese brakes, they use the exact same pad as another company, but without telling anyone. Do me a favor and fax (805-988-2948) me a tracing of both brake pads and I'll see if they match up with anything we do. Please put "attn. Andy" on the paper and give me your contact info.
    Andy- bicycle division manager- Galfer USA
    Reputation: 006_007's Avatar
    Quote Originally Posted by uber-stupid
    I second what uber-stupid said. Especially the part about the koolstop pads.
    check out the park tool website as it has a fairly good description for setting up v-brakes.
    http://www.parktool.com/repair_help/...arbrakes.shtml
    Get your freak on!
    Guys, he has DISK brakes, so telling him how to set up V brakes isn't much help LOL!
    Look around for EBC pads, they should have fitting pads that are decent quality.
    Also maybe Galfer can help you(above). I'm not sure if Koolstop makes pads to fit your brakes, but if they do, then get those.
    Another option in the future is to upgrade to something like a Avid Mechanical or even a hydro. These will give you far better performance upgrades over any pad.
    Sep 2004
    thanks
    Thanks for all the help guys. I've checked out both EBC and Kool Stop and it SEEMs that they carry replacement pads for my tektro disc brakes.
    http://www.koolstop.com/brakes/DiscBrakes/
    http://www.beyondbikes.com/bb/ba/asp...tm?link=bestwb
    I'll call them up and ask to make sure. Also, ebc carries the green and gold pads, but not reds. Which ones do you guys feel have better stopping power? Thanks again. Also, I'll contact you Galfer if I still can't find what I need.
    yeah... oops
    I saw "tektro" and forgot they're making disc brakes now.
    I hope pads fix the problem for you...
  1. Magura Marta brake pads?
    By Markv in forum Brake Time
    Last Post: 08-26-2004, 03:05 PM
  2. best V brake pads? not SS specific...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 08-11-2004, 03:04 PM
  3. Lost bolt that holds disc brake pads!
    By OffRoadRoadie in forum Brake Time
    Last Post: 07-29-2004, 12:48 PM
  4. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  5. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
