Results 1 to 6 of 6
    Dec 2009
    New BB7 MTN S in 2014
    I see there will be a new version of Avids BB7 in 2014:
    BB7 MTN S Mechanical Disc Brake | SRAM
    I think it looks better - but does anybody know if there are funktional improvements/differences to the older BB7 (without "S")?
    They should be lighter, but will they stop/feel better who knows.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by DerBergschreck View Post
    The only changes I am seeing are the finish, provided rotors, organic pads (rather than metallic). Weight is for caliper only while the "regular" BB7 weight includes the rotor.
    I doubt the S is lighter, but it does cost $30-40 more, so it must be better
    Hope the old version has not been dropped.
    mtbtires.com
    B A N N E D
    Looks like the "S" is because it comes with "Stainless Steel Hardware"
    It also looks like they don't recommend it for certain types of riding with the stock rotors and pads that they supply with it.
    Organic Pads & HS1 rotor
    Intended Use: Cross Country, Trekking, Comfort, Mountain
    BB7 Mountain? Mechanical Disc Brake | SRAM
    Sintered Pads & G2 rotor
    Intended Use: XC/TRAIL/AM/FR/DH
    The new BB7 S has a listed weight of 197gm for the Caliper Only (this weight must be with the CPS hardware, the IS to PM adapter and IS mounting bolts too)
    Old BB7 = 155gm
    160mm front IS to PM adapter = 14gm
    CPS hardware = 21gm
    IS adapter bolts = 11gm
    Sintered pads = 24gm
    Organic pads = 23gm
    160mm HS1 rotor = 90gm
    160mm G2 rotor = 104gm
    The old BB7 has a listed weight of 329gm
    155gm caliper + 14gm adapter + 21gm CPS hardware + 11gm IS adapter bolts + 24gm pads + 104gm rotor = a total of 329gm
    * 6 rotor bolts weigh 14gm so it doesn't look like they're included in the weight.
    New BB7 S
    197gm caliper (with mounting parts) + 23gm pads + 90gm rotor = a total weight of 310gm
    * I'm only guessing that this would be the total weight of the new BB7 S with a rotor and pads.
    14gm rotor weight difference + 1gm pad weight difference = 4gm difference in the weight of the old BB7 caliper and the new BB7 S caliper.
    4gm = less then the weight of one IS adapter mounting bolt.
    The older silver Type N BBBD / BB7 from 2002 to 2007 was 13gm lighter then the newer dark grey/black BB7 from 2008 to present day.
    The old 2002/2007 BBDB/BB7 caliper would therefore be lighter then this new BB7 S caliper.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    they are ridiculously over priced. for 120 bucks each..? I'm not a big fan of hydro but I'd get some Magura M2's for less 1st..
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    At that price....you're better off going Hydro. If you had BB7 before - this is close to a lateral move, at a higher cost.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. 2014 anyone?
    By druidh in forum Salsa
    Last Post: 08-08-2013, 07:08 PM
  2. 2014's On Konaworld.com
    By Uruk-hai in forum Kona
    Last Post: 07-15-2013, 02:04 PM
  3. 2014?
    By toddre in forum Diamondback
    Last Post: 07-12-2013, 10:59 AM
  4. 2014 When?
    By stygz1 in forum Specialized
    Last Post: 05-23-2013, 04:12 AM
  5. 2014,when ?
    By Devastazione in forum Cannondale
    Last Post: 03-30-2013, 12:20 PM
