    shred my gnar
    Reputation: happy_ending's Avatar
    need some "wrench" advice on juicy rub...
    see my last post on this thread... ive read through most of the rub threads and there isnt really consensus on this beyond resetting the cps bolts... THANKS!
    Brand New Bike w/Brake Noise?
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    Is your rotor true?
    A few things could cause rubbing that occurs with the bike weighted or not.
    This is in order of most likelyness.
    1. Rotor is bent
    2. Caliper is not aligned
    3. Wheel not all the way in dropouts or in crooked.
    4. Brake lever has been squeezed w/ wheel out
    5. Brake rotor loose
    6. Hub loose
    If the rubbing only occurs when riding it is something due to flex in the frame/wheel. Make sure your QRs are tight! Adjust the brakes with the QRs tight (especailly on the front), if you adjust the brakes with it loose then tighten it up it wont be the same. Check the hub for play. Check suspension bearing/bushings for play.
    shred my gnar
    thanks! to the garage i go...
    Meh.
    Reputation: XSL_WiLL's Avatar
    See the post I made in the other thread.
