Results 1 to 6 of 6
    Need new XT hub: disc-compatible vs non-disc
    Hi all,
    I need to replace the rear (Coda) hub on my vintage-ish Cannondale. This is a late-90's bike, from when disk brakes were not too common. I *think* it has bosses on the swingarm for a caliper, so I figure I might want to put disks on it when I'm feeling bored/wealthy.
    If I'm going to run V-brakes for now, is there any reason *not* to use the disk-compatible XT hub? I assume it's a bit heavier, but are there any other negatives?
    Meh.
    Reputation: XSL_WiLL's Avatar
    The offset of the hub flanges. The non-disc has a wider flange spacing, so it can build a stronger wheel.
    Jul 2003
    No reason not to....
    as long as you don't mind the weight difference, 496g for 6 bolt disc hub, 455 for non-disc.
    It's even becomming more common to see disc hubs on bikes that aren't speced with disc brakes from the major manufacturers. This is one area that I believe bike manufacturers are actually doing the customer a service. Not having to get a new wheel set or as a minimum hubs takes a quite a bit of the sting out of upgrading to disc brakes. So go for it. The only down side is disc hubs do tend to cost a bit more than their non-disc counterparts (if there is one), but usually it's only by $10 or so. But if you have any intention of upgrading to discs in the future you'd be ahead of the game going with disc hubs.
    Good Dirt
    Linoleum Knife
    Reputation: forkboy's Avatar
    snip...
    I've always wondered about this and right now I believe the opposite-- rear disc hubs can be built stronger because there is less dish. The non drive side tension can be higher.
    I recognize that the wider flanges matter but doesn't dishing and spoke tension count too? I'm really curious.
    Thanks for the info, everyone. I guess I'll just go with whatever proves cheapest. :-) Since I live in a dry environment, disc brakes aren't a very high priority for me.
