Results 1 to 3 of 3
    Need info on XT brakes vs XTR
    Hi my bike is in the shop ready to collect. But one snag Shimano main distributor have no XTR brakes and no lead times. So I may have to go for a set of XT calipers instead.
    Does anyone have any experiece of XT brakes here? How good are they and what weight sacrafice is there over XTR.
    I already rode that
    Reputation: SuperNewb's Avatar
    Try the 525 calipers? I heard they were just as light as the XTR's and lighter then the XT's and the people that used them were pleased with them.
    Im talking about the ones that look like the XTR's not the XT's.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    The XT is the same caliper as the XTR. The only difference is the XT's have less of the main body material shaved off making them a bit heavier. Functionally they are exactly the same brake and perform identically. They also only come in 74mm post mount so you are required to run adapters to put them in IS mounts just like you would with a Hayes or Avid brake. The adapters are mainly what contributes to the additional weight. XTR's come in IS specific mounts which makes them lighter. If you run a manitou fork the weight increase on the front will be very little since no adapters would be required.
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. Question about a new rear Derailleur, XT vs XTR.
    By Dean in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2004, 07:31 AM
  3. Shimano XT vs. XTR disc brakes?
    By frank daleview in forum Brake Time
    Last Post: 06-09-2004, 10:46 AM
  4. SJ 04 XT Disc Brakes or XTR
    By Steve Eungblut in forum Specialized
    Last Post: 04-14-2004, 12:05 AM
  5. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
