    Oct 2013
    Need help to set up rear IS XTR brake caliper (160mm rotor) to a post mount
    I have a XTR rear break that is IS mount. Frame has post mount set up to receive the caliper. TXS! Where do I start?
    El CicloPath!!!!!!!
    Nov 2012
    Is it the latest XTR model? It should install without any adapters needed.
    or..........................
    Shimano Mount Adapter for Rear Post Mount on the Bike Frame to an IS Caliper
    B A N N E D
    Quote Originally Posted by Fachiro1 View Post
    Latest model XTR's don't come with IS mounts.
    The following thread shows that it can be done.
    Link: My ghetto rigged XTR IS (M965) to post mount..
    To use a 160mm rotor you'll need a 'short arm' front 160mm/rear 140mm caliper
    The minimum rotor size you can use with the 'long arm' front 180mm/rear 160mm caliper is 180mm
    The following 160mm adapter would be needed to use a 160mm rotor with the 'short arm' caliper and to use a 180mm rotor with the 'long arm' caliper.
    http://clee-cycles.co.uk/esite/P1043/product
    The caliper on the left is the 'long arm' front 180mm/rear 160mm
    The caliper on the right is the 'short arm' front 160mm/rear140mm
    Need help to set up rear IS XTR brake caliper (160mm rotor) to a post mount-p4pb8600158.jpg
    Oct 2013
    Nope! I guess it is a 2-3 year old XTR. It is a IS mount. Bolts go in sideways to the bike. Horizontal to the ground.
    I need something to adapt IS to post mount.
    Txs!
  1. Brake Caliper Clearance on DMR Revolver SS Hub with 160mm Rotor
    By quagmire_1985 in forum Wheels and Tires
    Last Post: 07-29-2012, 09:04 PM
  2. Rear brake caliper mount holes stripped out
    By naiku in forum Brake Time
    Last Post: 07-10-2012, 03:15 AM
  3. Replies: 7
    Last Post: 01-02-2012, 10:34 AM
  4. Replies: 18
    Last Post: 11-13-2011, 07:58 AM
  5. XT Post Mt. Caliper to 51 I.S. fork 160mm Rotor
    By mgsuarez in forum Brake Time
    Last Post: 08-12-2011, 07:30 AM
