Results 1 to 2 of 2
    need help from people who know Marta's reasonably well
    My new old stock Marta was kinda dragging in the rear. (pads weren't retracting well)
    I thought I'd loosing them up a bit by using the Marta trick where you hold one side of the piston in and then cycle the brake to push the other piston out. And repeat.
    I accidentally went too far the oil starting coming out from behind the rubber diaphram on one side of the caliper.
    I quickly grabbed a screwdriver and pushed it back in, but it took alot of force and felt like I might have broke something.
    Did I ruin my caliper? I'm not really sure how those pistons sit in there and if I messed it up by forcing it back in.
    Thoughts? They both still move, but I lost some oil and probably introduced some air into the system so I can't quite tell if they're o.k. or not.
    Please help!
    you might have contaminated/damaged the seal, and or the piston. the best thing to do is a re-bleed. if it seems to be to hold pressure remain dry etc, then you've hopefully got away with it.
    if not you might be looking for a new caliper. magura don't do seal kits.
    good luck.
