Results 1 to 6 of 6
    Bipolar roller
    Reputation: singletrackmack's Avatar
    Oct 2012
    Need help with (old) BB7 front brake pulsing
    My old front BB7's are pulsing, but only when I brake hard. I am thinking I need a new rotor, but am not sure if it could be the pads or a set up issue that is causing the pulsing.
    Is the old rotor most likely the cause?
    If so, what modern day rotor would you suggest I get to replace this one so that it will be compatible with my old BB7 calipers? The front is a 185mm and the back is 160mm.
    Thanks for any help. Nice to know more before I start ordering parts.
    Get out of the gutter and onto the mountain top.
    "I only had like two winekills captain buzzcooler"
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    it's probably just warped.. straighten out the rotor and it'll be fine.. new pads and a light sanding of the rotor will help also.
    another thing is if you have cup and cone bearings (mostly shimano) if they are worn or too loose they will cause a wobble under braking,,,
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by singletrackmack View Post
    Avid use to have problems with uneven rotor thickness which caused pulsing. Have not seen it in years, though.
    Any 6-bolt rotor of the proper diameter works, as long as the braking track is wide enough.
    mtbtires.com
    Bipolar roller
    Oct 2012
    Quote Originally Posted by thomllama View Post
    Are you referring to the wheel hub bearings causing the pulsing? If so the hubs are Easton's. Not sure if they have cup and cone bearings.
    Bipolar roller
    Oct 2012
    I checked for the rotors to see if they are warped and they look to be very straight.
    I also lightly sanded them before my after noon ride. I sanded the top dirty layer off just to the point were they were shinny again, but I still had the pulsing issue during my ride.
    I found these in another post regarding changing out the old BB7 Rotors.
    Alligator Round Rotor | Alligator | Brand | www.PricePoint.com
    They are not expensive, so I might be trying these and some new pads if I can't get it figured out.
    Bipolar roller
    Oct 2012
    I just realized that these rotors come in a 180mm, but I have a 185mm.
    Can I use a 180mm?
    If I can will I need to adjust the calipers?
  1. Front brake vs rear brake
    By Ladmo in forum Brake Time
    Last Post: 01-25-2013, 07:51 AM
  2. Pulsing Avid Elixir 9
    By rgrieve in forum Brake Time
    Last Post: 06-07-2012, 06:38 PM
  3. pulsing lever
    By brankulo in forum Brake Time
    Last Post: 03-18-2012, 07:31 PM
  4. brake lever pulsing - what's causing it????
    By retro83 in forum Brake Time
    Last Post: 03-15-2012, 07:32 PM
  5. Replies: 2
    Last Post: 04-08-2011, 02:07 AM
