Results 1 to 3 of 3
    Think different
    Reputation: Daniel's Avatar
    Need help with Juicy Five
    Bought a new Avid Juicy Five brake set for my girlfriend's bike. The front brake installed well. But the rear rotor doesn't fir between the pads! I've tried to unclench the pads with a flat screwdriver, but I coun't get them far enough to fit the rotor. Anybody experienced such problem? TIA
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Three possibilities spring to mind:
    1- You just need to pry them apart a bit more firmly, using constant pressure, so that you force some fluid back into the reservoir. Right now the pistons are probably out too far and just need to be pushed back. Use something which won't take chunks out of the pad material like a thin paint scraper shoved all the way between the pads to pry with.
    2- One or both pads is not seated correctly. They may only be shoved in most of the way and are riding on top of the knob in the middle of the pistons and so are not fully seated agains the pistons. Make sure the pads are shoved up fully into the caliper.
    3- There is too much fluid in the system and the reservoir cannot accept any more, so you simply cannot shove the pistons in completely. This seems a bit unlikely, but possible. That would require a bleed I think.
    My video techniques can be found in this thread.
    Think different
    Thanks for your advices. The pads are seating on the pistons right, but one of the pistons sticks out for about 1.5mm. I've tried to push it back but it didn't go. Do you think I have to bleed it?
    Oh, forgot one more thing: how do I remove the pads??
  1. Avid Juicy 5 or BB7 Mech disc brakes?
    By journey in forum Brake Time
    Last Post: 05-05-2005, 04:31 AM
  2. Goodridge lines on Juicy 7
    By Ventanarama in forum Brake Time
    Last Post: 05-04-2005, 09:26 PM
  3. diff. between Juicy 7 and Juicy 5
    By danK in forum Brake Time
    Last Post: 10-07-2004, 08:51 PM
  4. Juicy rant | Mtn high cyclery rave...
    By incubus in forum Brake Time
    Last Post: 08-03-2004, 07:19 AM
  5. Avid Mech / Juicy adapter & rotor compatibility?
    By El Kabong in forum Brake Time
    Last Post: 05-28-2004, 09:01 AM
