Results 1 to 6 of 6
    Need help identifying/replacing brake pads - Tektro Aquila
    I am looking to replace/upgrade my Tektro Aquila brake pads with something other than the OEM part. I just removed my front brake pads and have confirmed them to be the TK-9895 pads found here: BTI | Tektro Disc brake pads, Aquila, Auriga, Draco - pair
    The brake pads that I am looking to replace them with are A2Z brake pads. Is this possible? I don't know much about this stuff, so I could use some advice. The specific A2Z brake pad I'm looking at based on visual similarities is the C0323 A2Z AZ-620. Would this work? I'm hoping this helps with brake squeal (primarily) and stopping power.
    B A N N E D
    They're the same pads as what's used with the Shimano BR-M525, BR-M495, BR-M475, BR-M465, BR-M416, BR-M415, BR-M375 and a few other models.
    EBC makes 3 pad compounds for this pad shape.
    BTI | EBC Brakes EBC disc pads, M525/515+LA/475* - gold
    BTI | EBC Brakes EBC disc pads, M525/515+LA/475* - red
    BTI | EBC Brakes EBC disc pads, M525/515+LA/475* - green
    * Some rotors are made to only be used with resin/organic pads.
    The a2z AZ-620 pads will work on your brakes.
    I'm sure that other brands make pads for your brake too.
    Oct 2014
    I have the same Tektro Aquila calipers and I am looking for non-metallic pads.
    It looks like these would also work:
    Kool Stop KS-D620
    Clarks VX811C
    edit: Also the Alligator HK-VX008
    Reputation: Mr Pig's Avatar
    There are loads of pads that shape, it's probably the most common pad shape out there. I use the Shimano B01S organic pads as they've always worked well for me, have nice feel and are quiet. Tons of choice though, too much! ;0)
    Oct 2014
    Quote Originally Posted by Mr Pig View Post
    Yup, I looked at them all and ordered 2 of the B01S a few minutes ago.
    Quote Originally Posted by GaryTheSnail View Post
    I'm sure there will lots of good pads, I'm no expert. I'm just sticking with what I know works. Hope you enjoy your new pads :0)
  1. Brake pads for Tektro rādius.
    By gtchuker2.0 in forum General Discussion
    Last Post: 08-18-2013, 11:21 PM
  2. Tektro Auriga Comp Disc Brake Pads
    By OFFcourse in forum Brake Time
    Last Post: 09-15-2012, 12:00 PM
  3. avid bb5 vs tektro aquila
    By KonaCalderaXC in forum Brake Time
    Last Post: 01-31-2012, 02:44 PM
  4. Are Avid BB7s Really Better Than Tektro Aquila?
    By XCSKIBUM in forum Brake Time
    Last Post: 08-26-2011, 03:27 PM
  5. What brake pads work with Tektro Draco SL calipers?
    By JacksonCampbell in forum Brake Time
    Last Post: 05-15-2011, 04:29 PM
