Results 1 to 45 of 45
    Thunder Chunky
    Reputation: Madman133's Avatar
    Need Help with Hayes 9's
    Ok so about 3 monthes ago i bought a new bike that had the hayes 9 fornt and rear on it. I have ridden it all of about 3 times mostly just around the neighborhood because on the cold weather. Today i noticed that my rear brake seemed to be getting looser and looser as it used to be just as tight as my front break. It got to the point where it didnt even slow me down at all and now it just hits the handle...Is it a leak? i dont think it is because i have checked the whole line and there isnt even a scuff on it. SHould i take it to my lbs and see if they can figure out whats wrong or should i try to bleed it and see if that helps at all?
    Thanks,
    Mad
    Race Technician
    Reputation: Randy@Hayes's Avatar
    Jan 2005
    Back to the shop...
    Have them make sure the hose fitting is tight at the master cylinder. If they are, time for a bleed.
    Randy
    Thunder Chunky
    k will do. Thank You!!!
    Reputation: Drew@WS's Avatar
    Adjuster screw
    Is your adjuster screw on the inside of your brake lever backing out? If it does not have loc-tite or the plastic shim in the cylindrical nut it will back out everytime you pull the lever and will get closer tot he grip in about 1/2 hour of riding.
    Thunder Chunky
    no thats not it i have tried screwing it all the way in and it doesnt do anything...
    Meh.
    Reputation: XSL_WiLL's Avatar
    Actually you don't want that reach adjuster all the way in. Try having the reach adjuster flush with the nut.
    Thunder Chunky
    ok i lied I didnt put it all the way in but I put it farther in than they were before. Then i didnt notice any difference so i decided to not put them all the way in to make sure i didnt do anything thing else to damage them further.
    Thunder Chunky
    ok today i decided i might as well try to rebleed it while i am waiting for Ibex to reply. So i repled it and it seemed to work great. That didnt really tell me wether it was a laek of just a bad bleed so i decided to just pump the brakes acouple times to see if i could find a leak anywheres. Well to say the least i found out...on about the second pump the line burst spraying the crap all over me. I looked at where it burst and it was just a tiny cut no abbrasion or anything that would cause it from what i could tell. So now im hittin Ibex up for a new hose. How hard are hoses to install? Easy enough for me to figure out(im pretty good if i got some good instructions) or would it be better just to have me lbs put it in?
    Thanks,
    Mad
    Thunder Chunky
    Randy,
    Im assuming you work for Hayes since it says Randy @ Hayes so im going to ask you this: I got a responce from Ibex basically saying its not ttheir fault and your company ships the the brakes already assembled. But they are gogin to contact you and see if they can work something out. For now he just had me email him some pics but he said i might also need to send those hose back for further inspectipn. Anyways do you think Hayes will give me a nwe cable or will i need to buy one do you think? Heres the pics(sorry for the big size but its hard to see otherwise)
    Race Technician
    Jan 2005
    Give us a call. 1-888-MTN-DISC for a RA#.
    Randy
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Thats a very interesting slice. Lucky your dealing with 2 very good companys in Ibex & Hayes. Both Jack & Randy are some of the best in the industry to be working with.
    Formotion Products
    http://www.formot
    Thunder Chunky
    I have not yet called Hayes since its the weekend so I will call on Monday. So far Ibex has been great about!!!
    Something looks oddly familliar..
    Hey, I noticed the location of the burst and had to chime in. Dual crown fork, right? I bet if you look at where the bumper on the stantion hits the frame you'll find that the hose is RIGHT there. Betcha that bumper is the cause. I've seen it before, on one of my old bikes. Technically not a warranty issue, but give it a shot.
    Thunder Chunky
    hmmm if that is the problem how do I fix it so it doesnt happen again? Ive never had that happen on any of my previous bikes...
    Jan 2005
    Quote Originally Posted by juancancook
    Thats a different one!! Guess i always made sure it never hit so i never saw the problem, nice call.
    If jcc is correct then relocate the rubber fork stops so they dont slam the hose but the frame instead. Also be sure the high end of the bumper is hitting the frame.
    Formotion Products
    http://www.formot
    Thunder Chunky
    ok just went and checked it out. That is NOT the problem. The spilt is about 2 inches away from where the bumper hits and the bumbper doesnt even hit the line in the first place.(And no i didnt move the bumper and even if i did i couldnt move the brake line so that the spilt isnt where the bumper hits). I can take pics if you want.
    Jan 2005
    Quote Originally Posted by Madman133
    Well juancancook had a great idea as a possibility. Well Randy is offering a RA # so it sounds like he is willing to inspect & possibly replace the hose. They will possibly have you remove the hose & send it to Randy/Hayes.
    Formotion Products
    http://www.formot
    Thunder Chunky
    Im having trouble getting in touch with Hayes...Ibex told me that since i had already been in contact with them on here it would be better for me to just do it myself(understandable and not a problem) Whenever i call the number provided by Randy though the automated voice thing picks up and i press 1 for warranty and tech support for disc brakes. After i do that though it says please hold for a moment or something like and then starts ringing but no one ever pics up??? I have tried at different times of the day with the same result? Am I retarded and doing something wrong? Or do i just have really bad luck at picking what time to call? lol
    Thanks,
    Taylor
    This might seem obvious but...
    ... did you leave a message?
    Thunder Chunky
    hmmm guess i never styaed on the line long enough...i must be really impatient compared to the rest of the world lol. Thanks!!!
    Jan 2005
    Send Randy a email exlaining the phone problem, possibly he can get you a RA# & email you back.
    Formotion Products
    http://www.formot
    Ah Ha!
    Simple solutions rock! Their voicemail can take a while to kick in but I've had no problems with them returning calls. Let us know what they do for you.
    Thunder Chunky
    ok you were right lol...left a message 2 minutes later they called back. Gave me a RA# and address to ship it to. One question though that i forgot to ask the guy. Should i just put like a peice of paper with the RA# on it in the box or where should i put the #? Actually another question too. What do i need to ship exactly he told me but i forgot to write it down...I think it was just full master cylinder and brake lever along with the hose obviously but i just want to make sure im sending them the right stuff lol.
    Race Technician
    Jan 2005
    Step one, cut a hole in the box.....
    Sorry, off topic.
    Take the brake off the bike, no need to send the hardware, adapters or disc, box it up.
    RA# on the outside of the box is all that's required.
    Randy
    Jan 2005
    The RA# goes on the outside of the box so they know where to send te box when it arives. If you are able to bleed the system, just the hose. If you dont know how to bleed call back & suggest you would like to send the compleat master, hose & caliper so they can set it up again.
    Formotion Products
    http://www.formot
    Jan 2005
    Quote Originally Posted by Randy@Hayes
    Sorry, off topic.
    Randy
    Really off topic----- Randy are you going to the Otter again this year
    Formotion Products
    http://www.formot
    Race Technician
    Jan 2005
    Yup
    Stop by booth 543 and see what's up for 2008. New brakes, rims, wheels and forks.
    I'm working to get our latest 2008 products on our demo bikes for Sea Otter use.
    Start praying to the rain gods to be nice to us this year.
    Randy
    Jan 2005
    Randy
    OhhhhAhhhhh i have a Versus Blitz II ready for some demo parts
    I need to find out what booth # but i'll email you a invite to the Versus BBQ.
    http://www.versuscycles.com/
    Formotion Products
    http://www.formot
    Thunder Chunky
    since we're off topic anyways Randy we should go bikign sometime...only problem is im in Central/eastern colorado in Castle Rock(aka 1/2 way between the springs and Denver)
    Race Technician
    Jan 2005
    Well....
    I'm on the Western Slope, Fruita actually.
    Randy
    Thunder Chunky
    Yeah thats what i meant we dont live very close
    Jan 2005
    Randy
    Oh come on Randy every where is your home when your on the road.
    Formotion Products
    http://www.formot
    Jan 2005
    Randy
    Massive Spam,
    Hay Randy can you PM me? I have a question/proposition.
    Formotion Products
    http://www.formot
    Thunder Chunky
    no worries just sent it out today...feel free to talk about whatever cause i think i might be waitng awhile lol.
    Jan 2005
    Awesome keep us posted!! I dont think you will have to wait that long, the season is just getting ready to start, i think the timming was good, not that a blown hose is good.
    Formotion Products
    http://www.formot
    Thunder Chunky
    so does Hayes giving me a RA# mean they accept it(cant think of a better term) and will ship me a new one right away ? Or are they still going to have to cheack it out?(i would assume they would at least look at it before sending me a new one lol)
    Race Technician
    Jan 2005
    We repair it and send it out the same day we receive it.
    Randy
    Thunder Chunky
    ok sweet...yeah i thought it might take a week or so but you cant beat same day!!! Thank you so much for all the help!!! It has been a pleasure dealing with Hayes and Ibex both.
    Thunder Chunky
    said it was delivered yesterday the 8th hopefully they come back soon...ive endo'd too many times this week lol...apparently im not too good at my weight shifting lol
    Thunder Chunky
    lalalalalaaaalalalalaaaaaaaa just waitin waitin waitin....im a very impatient person lol
    Purple Popcorn
    Jan 2005
    Do you still have the cream
    Formotion Products
    http://www.formot
    Thunder Chunky
    Quote Originally Posted by dogonfr
    naw...i used it all up when i rebled the brakes and didnt have any extra brake fuild lying around....worked so good it popped those lmao j/k j/k. Why? Are suggesting something sexual? lol cause if so count me in like my new sig btw?
    Purple Popcorn
    Jan 2005
    Not me, im inosent
    Nice sig
    Formotion Products
    http://www.formot
    Thunder Chunky
    Got it today . Gave me a brand new one because the one i sent back to them was cracked/cut the whole length of the tube and then just burst through the outter skin at that one place lol. Anyways put it on and used my famous syringe to bleed it lol. Also you guys got me in "trouble" lol in the note they sent back with it, it said next time you send anything back to Hayes or any company make sure to include the whole setup lol . Also want to thank Hayes again for their great customer service!!!
    Purple Popcorn
    Jan 2005
    Whohooo ride-on.
    [quote=Madman133Also you guys got me in "trouble" lol in the note they sent back with it, it said next time you send anything back to Hayes or any company make sure to include the whole setup lol . Also want to thank Hayes again for their great customer service!!![/quote]
    It is not always easy to explain how to send it all back except the mounting hardware.
    Quote from Randy : Take the brake off the bike, no need to send the hardware, adapters or disc, box it up.
    Randy - End Quote
    Formotion Products
    http://www.formot
