Need help with 08/09 Magura Marta SL issue.....
Hi all, I need some help please.
I have a set of 2008 Magura Marta SL's.
I purchased them new last year, and last weekend I noticed the rear brake needed a bleed.
No problem, I've done the front just fine.
So, After following both directions from the bleed kit and their online tutorial, I ran into a major issue. Oil started leaking from the rear caliper. So, I got ahold of Magura, and they sent me to the nearest "Licensed Magura Dealer." I showed the head shop mech the caliper, and he called his Magura rep. No problem, they're going to send me a brand new caliper and some more oil. Sweet
It came in today! So, I rush home and open up the box.....
They sent me an 09 post mount Caliper.
Here's my issue. I now need a new rear adapter, as the 09s Calipers all come post mount.
Also, my fairly new brake pads from my 08 set won't work in the 09s, so I now also need new pads.
I called the shop back, and he pretty much directed me to Pricepoint.com for both adapters and pads, advising me that's the "cheapest I'll find them online."
Another thought.....since the 09 Marta SL's are redesigned with a larger master cylinder and caliper.....will my 08 Lever's work correctly with the new rear?
What would you guys do? Is there a Magura rep here who I could speak with?
Thanks for your time,
Nick
You need the Magura QM-12 adapter for a 160 rear
Oops, for go to mention you want Louise brakes pads, that is what fits the 2009 Marta's
Thanks for the quick reply!
I forgot to mention, but I have both 180mm Wavy rotors, front and rear. What's the correct rear caliper adapter to work not only with the 180, but with a post mount?
thanks much
nick
thanks much
nick
QM-10
 Originally Posted by pastajet
QM-10
You're my hero today
Do you, or anybody else know, if the redesigned 09 rear caliper is compatible with the 08 lever?
thanks again,
nick
thanks again,
nick
It will work with no problems.
On a side note, imo if Magura couldn't send you identical replacement for your faulty caliper, they should've sent you pads with the new caliper as well.
- You may not post replies
- You may not edit your posts
Forum Rules
