Results 1 to 13 of 13
    Reputation: crclawn's Avatar
    Need to cut brake hose line on prebleed brakes, will I have to bleed brakes?
    My hoses are too long for my bike. I need to cut them. Will I have to bleed the brakes after I cut the hose?
    When the **** did we get ice cream?
    Quote Originally Posted by crclawn View Post
    it depends on the brakes you have
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    I've shortened hoses on Magura Marta SL- no need afterwards and Avid X.O elixer - needed bleeding. So yeah, depends on the brake.
    Amolan
    Shimano you can normally easily get away w/o a bleed.
    Just keep the hoses vertical so you don't lose any fluid.
    Thanks. I got a bleed kit coming in the mail. Should I just wait until I get it to attempt it? No big hurry to cut.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    I'd wait to be safe. You probably don't need it, but if you slip up it's nice to have the insurance.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I'd probably wait . . . that way, if you DO need to bleed, you won't be waiting for the bleed kit.
    Reputation: FLMike's Avatar
    another vote for waiting for the bleed kit just in case....
    May 2010
    Should be no probs, I've shortened Shimano, Hayes & Avid.
    Get all the bits ready, unbolt @ H/bar, shorten, reattach. If a tiny bubble has entered, gentle squeezing of the lever allows it to escape into the reservoir. Usually not needed.
    Don't cut too much........
    If yer smart, no, you won't. Reset the caliper pistons by removing the pads and pushing the pistons all the way back into the caliper body. This puts the diaphragm in the reservoir in it's neutral state, it won't draw air into the master cylinder. Keep the hose port up to 12o'clock while you shorten your hose and insert the new compression olive. Top the port off with Shimano mineral oil and thread the compression nut back into the port, keeping the port at 12. Some of the mineral oil will weep out as you do this. That is fine. You want to keep the system flooded so to speak to prevent any air from getting ingested in the mc. Once the comp nut is tightened down enough so the hose doesn't twist unless you reeeeeeallly torque on it, you're done. Clean it up, install the pads, mount it to the bike, and check the engagement.
    You are not what you own.
    Cut just fine. No bleeding at all. XT Deore brakes are super sweet!
    Reputation: illcomm33's Avatar
    I was always suspect but after cutting Avids, Shimanos and Hope lines down I am a believer. Make sure to keep that hose vertical and you shouldn't have a problem. Always easiest with 2 people.
  1. Elixir brake hose on X0 brakes?
    By drewgold in forum Brake Time
    Last Post: 01-15-2011, 06:28 PM
  2. Hope brake bleed hose
    By ebarker9 in forum Brake Time
    Last Post: 04-12-2010, 08:16 AM
  3. Replies: 0
    Last Post: 02-06-2009, 06:16 AM
  4. Replies: 9
    Last Post: 04-10-2008, 09:30 PM
  5. Replies: 1
    Last Post: 07-11-2004, 07:12 PM
