    Ride or die
    Reputation: mountainbikeloco's Avatar
    Need bling hydro hose
    I am running some Elixer Cr's and want to find some red braided hose to fit my scheme. Does such a hose exist? If so where can I find some?
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Check out my SportTracks plugins for some training aid software.
    T.W.O.
    Reputation: mimi1885's Avatar
    May be check out Jagwire too. Check the diameter of the hose, if it's too small it effect the performance. You may have better luck with Jagwire than Goodridge. I have 2 brakes that I switch to Goodridge, the silver braided ones, on my J7 and Marta SL.
    I wanted to change my Louise carbon bat hose to red a while back, ordered goodridge, but back order. Several phone calls later to Goodridge, BTI, and LBS, I gave up. They all said different things. I know Jagwire offer similar things I may look into if for my next swap.
    switchback sculptor
    Reputation: erosive's Avatar
    You can get heat shrink tubing in lots of colors at good hardware stores.
    Slide it on, shrink it down, cheap bling!
