Results 1 to 3 of 3
    Need Avid Juicy 7 Help.....
    I went over the bars and jammed my front brake lever into the ground and now, I can push the lever forward and it does not stop until it hits the reservoir body. The brakes still work fine but the lever has a lot of front to back play and the lever does not spring back like it used to when released.
    Any help you can give is greatly appreciated.
    Thanks,
    Greg
    meh....
    Reputation: Monte's Avatar
    Did you put the dangerboy levers on? Take the lever off and see what's wacked.
    Meh.
    Reputation: XSL_WiLL's Avatar
    The pushrod/sleeve may be damaged. It's a cheap part to replace, but it'll require a bleed.
