Results 1 to 6 of 6
    Need advice 2 shorten rear '06 Juciy5 hose.
    So I need to shorten the hydro hose on my rear '06 Juicy 5. I thought I recall reading here somewhere that this can be done without needing a bleed kit but I can't find the thread. So, is it possible to cut the hose down without needing to bleed the system? If so, all tips and hints are appreciated.
    thanks in advance,
    simp
    Meh.
    Reputation: XSL_WiLL's Avatar
    You'll need a new barb and compression fitting. But yes, if you are careful about not squeezing the lever and not dripping out fluid, you may be able to get away without bleeding. However, I've found that the factory bleeds usually aren't perfect anyways. So you should just pick up the bleed kit.
    Roger that. Thanks for the advice. I'll get mah-self a bleed kit. Anything else that I'll need? Special tools? My tool kit is extensive but I've never been through the bleed process before...
    cheers,
    simp
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Sram has the bleed kit instructions online.
    Going for a ride......
    Reputation: energetix's Avatar
    Feb 2006
    Also check the parktool site - they've got good bleeding instructions for Avid, Hayes & Shimano in their maintenance section!
    Ah what the heck here is the link for you. (click on "AvidŽ Hydraulic Caliper Brake Installation & Hose Length Changes" from the link below).
    http://www.parktool.com/repair/byreg...mageField2.y=9
    energetix
    Quote Originally Posted by energetix
    Doh....
    Park Tool Website.
    What was I thinking... I guess I wasn't.
    Thanks much....
