Results 1 to 3 of 3
    powered by bacon
    Reputation: helidave's Avatar
    need adapter help
    I'm putting a Pike with IS mounts on my Trance, which currently has a Marzocchi fork with post mounts. I need an adapter for a Shimano 486 caliper and 180mm rotor.
    B A N N E D
    You'll need one of these.
    Friendly Neighborhood MTBer
    Reputation: kabayan's Avatar
    Need help with numbers stamped on adapters
    What do the numbers stamped on the side of the disc brake adapters mean?
    I have 3 disc brake adapters
    One has a 31 on it - seems to work with Hayes 180mm rotors on post mount forks
    One has a 33 on it - seems to work with Hayes 180mm rotors on IS rears
    One has a 34 on it - where would this work?
    Or better yet, where can I find an explanation for the numbers?
    Thanks.
    If you can't play, display.
