Results 1 to 3 of 3
    Need 180mm rotors , XT's ?
    I am in the market for a set of 180mm rotors. I came across a good deal on Shimano XT's - any comments on these rotors ? I have a Haye's Mag brakeset and was originally going to go w/ V7 rotors but my current V8's are quite noisy just banging thru rocks (make pinging sounds) Thanks
    I don't like mine. It's paired with XT m755 4pots. It screeches when braking. I guess it has something with the 755's metallic pads. I think if I went with organic pads, it would be silent but with less stopping power.
    Reputation: vk45de's Avatar
    Make sure the brake track is wide enough. Shimano have the narrowest brake track so their calipers are fine w/ other rotors but you may end up biting on the rotor spoke w/ your hayes.
