Results 1 to 14 of 14
    Jun 2013
    n00b question with adding rear disc caliper
    ok so I picked up this bike today. It's a 2004 Gary Fisher Tarpon Silver Series (aluminium frame). The previous owner told me it had front & rear disc brakes installed and the rear caliper "broke". However, when I picked it up I noticed the bike had pull brakes installed on the rear and no caliper at all. he said when it broke he pulled it and put the pull brake back on. /shrug.
    so I've NEVER dealt with disc brakes at all before and am a complete newbie at all of this so please pardon me if this is a completely stupid question.
    How do I install a rear caliper? It uses Shimano BR-M415 (yes I know....) calipers and I can get a new one and I see the two holes that would most likely be used for the installation but there is a "quick release" lever that seems to be in the way of installing it.
    Can this lever be replaced with something else that won't impede the installation of the caliper or am I just completely daft?n00b question with adding rear disc caliper-dscf6373.jpg
    May 2012
    Re: n00b question with adding rear disc caliper
    Just loosen the lever, turn it and fasten it again. It's really simple..
    Jun 2013
    boy, do I feel stupid. LoL. awesome though, thank you very much! now to order my new caliper.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by echarlie View Post
    You need more that just the brake caliper. Your frame is missing the factory bolt-on disc brake mount.
    n00b question with adding rear disc caliper-post-24908-0-90751100-1312388507.jpg
    mtbtires.com
    Dave's not here.
    Reputation: MiWolverine's Avatar
    Is that a crack on the upper bolt hole? If so, I would steer clear from mounting a disc caliper on there.
    I am the world champion of bad luck, but I tell you what, I'm undefeated!
    Jun 2013
    Quote Originally Posted by MiWolverine View Post
    Good eye but thankfully, no its just a line of dirt. LoL sorry, hadn't cleaned it very well yet when I took the pic.
    well, crap. I texted the guy to see if he still has it. I told him it's probably still with the broken caliper. he said he will check. I hope he finds it.
    if he doesn't what are my options?
    Dec 1998
    The mounts show up on eBay.
    mtbtires.com
    B A N N E D
    Go to a Trek dealer and get them to order you one, they still use this mount on the 3 series bike models.
    Also available on ebay.
    IS Mount: Rear Disc Brake Adapter for Gary Fisher Trek Klein Frames Universal Mount Disk | eBay
    Post Mount: Rear Disc Brake Adapter for Gary Fisher Trek Klein Frames Universal Mount Disk | eBay
    Jun 2013
    Quote Originally Posted by shiggy View Post
    ok, thanks. what would I be looking for specifically?
    Jun 2013
    thanks cobba. they're pretty proud of the thing for such a simple bracket. let's hope he finds the old one for me. LoL
    Jul 2013
    You can also take out the QR and put it back in the other way so it tightens from the cassette side. I would not recommend putting it in the forward postition like in the picture of post #4, It is too easy for something to hit it and unlock it from the forward position. QR's should be clipped back or up, not down or forward.
    You don't need to get an M415 caliper just because that's what came on the bike. I wouldn't recommend it either. A BB7 caliper is probably not too much more. Put the BB7 up front and your existing M415 in back, or just get two BB7 calipers.
    I used the Shimano M415s for about 6 months. I bet the rear v-brake on your bike could work better (assuming its adjusted properly and there's no pad or rim contamination).
    Jun 2013
    I went to the Trek store and they ordered the correct bracket for me for $15. New caliper (yes I know I should have probably gone with Avids or something instead) cost me $35. Thanks for the help all!
    Jun 2012
    Have fun dude, when in doubt ask a question.
  1. Replies: 12
    Last Post: 09-14-2013, 11:34 AM
  2. Mounting Rear Disc caliper on a 2012 Mamasita
    By Haystack Calhoun in forum Salsa
    Last Post: 02-09-2013, 02:21 PM
  3. N00b reporting in with first n00b question - cranksets
    By iltridente in forum Beginner's Corner
    Last Post: 12-28-2011, 01:09 PM
  4. 22mm Hayes rear disc caliper
    By GNR in forum Trek
    Last Post: 08-06-2011, 10:21 PM
  5. adding rear disc to older steel frame- custom welding
    By 2silent in forum Frame Building
    Last Post: 02-22-2011, 06:57 PM
