Results 1 to 23 of 23
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    My DIY Avid bleed kit.
    Found that the rear Juicy 7 on my bike needed bleeding the other day - then found that Avids needed a special bleed kit to bleed them - $40 being the cheapest I could find. Or take it to the LBS...
    I had a hunch about the size of the connectors, and I had some 4mm plastic garden irrigation hose fittings in the shed. I also had the right sized hose lying around. Again, cheap garden irrigation stuff.
    What do you know - they screw into the bleed holes perfectly and sealed up fine. I thought I might need to source some small O rings, but no.
    Here is the little barbed fitting I used for the connector - I cut off the pointed tip from one end. That screws into the bleed hole. The hexagonal end seals OK against the lip of the bleed hole if you screw it down firm.
    Two 45 cent syringes from the local pet supply place and $15 for a 500ml bottle of Dot 5.1 and I was ready to go.
    I had planned on installing some taps into the bleed kit lines, instead of using clamps - on impulse I tried the kit without them or clamps and it worked fine anyway - maybe a wee bit more spillage but not much.
    Hope someone finds this useful.
    Less isn't MOAR
    SSolo, on your left!
    Very nice!
    Get off the couch and ride!
    Reputation: DosNueve's Avatar
    Feb 2012
    Quote Originally Posted by Sideknob View Post
    Nice find. I actually looked everywhere last year for something like this. end up buying a kit at the LBS.
    Reputation: mitzikatzi's Avatar
    Great post
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Thanks guys.
    Just been out for a couple of hours - brake worked fine.
    Less isn't MOAR
    Reputation: dirtyjack's Avatar
    I don't see a hose clamp, so I'm assuming you didn't de-gas the fluid before pushing it into the caliper? It's an important step to getting a good bleed with 5.1
    I'm a little obsessive, I de-gas 5 or 6 times to be sure I pull out as much air as I can before I push it. 5.1 is fussy stuff compared to mineral oil.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Ive never "degassed" any of my bleeds, and my brakes work just fine. I personally think this is an Avid gimmick.
    Of course I did - it's not hard to push bubbles out of a syringe. I used to stick them into people, you know - it was pretty important not to give a person an air embolism.
    I was going to use little taps in the lines - decided to try without them and it worked fine.
    Less isn't MOAR
    Quote Originally Posted by nov0798 View Post
    YMMV, but degassing worked noticeably better with my XX's. Can't say I noticed a difference on my Pugsley with Elixir 5's.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Mine work just as well as they did when new now. Anyway, take my DIY kit FWIW. Just putting it out there.
    Less isn't MOAR
    I got my kit on e-bay for $20 shipped which incl the fluid, two syringes fitted with hose fittings and pinch valve. Still, I like your improv. Nice.
    Dec 2005
    Degassing is a gimmick-most of the "air" is just sucked past the o rings amd it only looks like you have de-gassed teh fluid. If you had that much soluble gas in the DOT fluid then you would have gas in your brake lines too. Ha -Just like Avids always seem to.....
    All I know is that when I push the fluid into the caliper, I then draw lots of big bubbles out of it. Same on the lever end.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Dec 2004
    Thanks for the idea! I had some similar irrigation nozzles laying around, and this worked like a champ. It's ridiculous to expect the consumer to buy a $50 tool just to bleed his brakes.
    BTW, I did it with only one syringe. Rather than having a second syringe at the top (on the lever bleeder), I attached about 6" of clear tubing to act as a reservoir. Since the bubbles rise, you can push fluid through the system until the tubing is almost full. Any bubbles will rise to the top of the tubing, so you can then draw your syringe back and pull fluid back through the system without pulling bubbles.
    AM.
    Sep 2004
    Where did you buy your irrigation supplies? The ones at Home Depot don't have those threads
    Sep 2004
    ...or wally world
    Sep 2004
    Oh wait, this is a British thing, isn't it.
    I don't think these fittings exist in the entire Americas.
    Dec 2004
    Here's what I used. I clipped the little cap off the top and used tubing large enough to fit over the round part of the nozzle. The specs listed on both the website and on the package don't seem to match reality. These threaded in pretty nicely, and being plastic, you shouldn't risk damaging the threads in your caliper or lever.
    180 Degree Spray Jets (10-Pack)-111B (search at Home Depot)
    AM.
    Mar 2015
    Nice having a machine shop friend
    I could not afford to have these made, but since there is a machine shop next to our welding shop I decided to ask a friend to make me a couple. They work like a champ.My DIY Avid bleed kit.-bleeder1.jpgMy DIY Avid bleed kit.-img_0736.jpgMy DIY Avid bleed kit.-img_0737.jpg
    Reputation: joshdurston's Avatar
    Feb 2010
    what is the actually thread spec? Is it M4?
    There is a machine shop where I work so I think I could figure something out.
    EDIT just search amazon for m5 barb, lots of options...
    http://www.amazon.com/s/ref=nb_sb_no...ywords=m5+barb
    Mar 2015
    M5 the only issue I ran into an ended up buying the pro kit was the actual bleed process. The adapters that come in the kit allow you to release the trapped air in you syringe's. You can get close but never get a clean bleed IMO without the kit. I even tried a vacuum pump to remove the trapped air bubbles. That did very little. After bleeding with the pro kit I did an unintentional endo and landed on my face. It is worth every penny. The nice thing is if you have friends go in on one kit and share it. Cuts the cost down. BTW I'm in Alabama if anyone needs help. The bleed process is tricky at first.
    Quote Originally Posted by joshdurston View Post
    Amazon.com: m5 barb
Members who have read this thread: 15
