Results 1 to 2 of 2
    Reputation: swl7's Avatar
    Sep 2012
    Is my brake oil leaking? Unaligned rotor/brake combo?
    So about a couple weeks ago, my brake pads were contaminated so I cleaned them up using isopropyl alcohol and it seemed to have gotten rid of my horse-like squeal noise coming from my rear brakes.
    Today, I went out to ride and after the end of my ride, I could hear the wretched sound coming again. It's not as severe as the first time, but it wasn't this bad when I cleaned up the pads.
    What I'm wondering is: is my brake fluid leaking in the rear cable that's attached to my brakes? (See picture) This picture is after my ride before I cleaned this black stuff off my brakes (after I washed my hands)
    Second question: How do I tell if my rotor + brake combo is unaligned? The rotor does not spin wobbly, but I noticed that some of the metal that is close to the rotor has scraped off!
    scraped off metal where the letter "W" is:
    my alignment on rear rotor + brake (is this because the angle of the photo sucks? the more I look at the rotor from any angle in person, it looks unaligned!):
    my front rotor + brake seems aligned. you can see the spacing barely:
    Thanks for the help. I've been getting into maintaining my bike to make less frequent visits to the LBS, but if it's something I can't handle, I don't mind taking it to the LBS.
    I'm not sure if I want to go ahead and do this (and if it's even necessary at this point), but I was going to loosen my rear brake caliper, turn the wheel, squeeze the brakes, and then tighten the two bolts.
    Sep 2012
    I'm very sorry for the rotations of all these pictures. I didn't even notice until I posted them (some are side-ways, upside down...lol)
    edit: and as a note. the brakes do work fine I believe. I'm just worried about any future damage/unreliability
