Results 1 to 30 of 30
    Reputation: smmokan's Avatar
    Is my Avid BB7 brake broke?
    I was cleaning out my brakes and rotors today and I came across a slight problem. I removed the brake pads in my front BB7s and was trying to put them back in... I turned the outer adjustment knob, and the small round piece inside the brake popped loose- the piece that sits behind the brake pad and pushes it into the rotor when you squeeze the lever. I can't get it to go back in for the life of me.... is this thing broken? If it is, do they warranty this kind of thing? It basically fell off without any kind of force or jolting.
    Some pics (you can see the round piece in the middle, when it should be up flush with the side of the brake).
    This shows it better- the bottom of the round piece was once sticking into the hole below it:
    Old man on a bike
    No, you just dialed the pressure foot out too far. The instructions on how to reseat it are on the SRAM website, get the technical manual here http://sram.com/en/service/avid/tech_manuals.php, it's in there....(and it's not all that involved, but I'll just let you read for yourself).
    suum quique
    Jul 2003
    Yup they're supposed....
    to be able to do that. Check out the tech manual, you'll be amazed at how far the caliper can be stripped down. And as long as you're at that point you may as well tear it down the rest of the way and clean and service the internals while your at it. Nothing teaches you more about your components and how they work than taking care of them yourself!
    Good Dirt
    Nope, it was broken- that small round piece had an end to it that kept it inside the caliper, but it apparently snapped off. If anyone wants a super cheap BB7 front caliper, shoot me a PM.
    Old man on a bike
    How about a photo of the broken part? The first photos seem to show everything intact...
    suum quique
    See the part in the middle of the brake that's round with the post coming out from one side (the only silver-colored piece in the picture)? That isn't attached to anything- its completely loose. It WAS stuck down in the hole, attached to something, but apparently it broke off or came un-attached somehow.
    Looking at the SRAM owners manual on their website, it appears as though it should be attached to another piece that sticks down into that hole and into several washers and other parts.... but it broke.
    Dirt Deviant
    Reputation: savagemann's Avatar
    If you push that piece back into its hole and turn the red knob on the outside it won't thread back in? Turn the knob clockwise.
    Look, whatever happens, don't fight the mountain.
    Nope, there's nothing to thread.... it isn't a screw. It has a ball bearing in the end of it (per the manual), and it appears to have been attached to some other part- but there's no way its just popping or screwing back into anything.
    Old man on a bike
    So this doesn't apply? (from the troubleshooting advice in the technical manual):
    The most common issue with the BB7 is that the
    outboard pressure foot can become dislodged if
    the outboard adjustment knob is turned too far
    clockwise without the rotor in the caliper (wheel
    off or caliper removed). The brake is not broken,
    nor does it require disassembly to replace the
    pressure foot. To replace the pressure foot, turn
    the outboard adjuster knob counter-clockwise
    until it stops. If the knob doesn’t stop, then the
    foot screw (the end of which can be seen in the
    center of the knob) has become disengaged
    from the knob and possibly from the threads
    inside the drive cam. In this case, remove the
    knob, then using a pair of small needle-nosed
    pliers or a schrader valve tool, turn the the foot
    screw all the way back out until it stops. Now
    the pressure foot can be replaced. Relocate the
    pressure foot into the bore, then give it a firm
    push in the center. It will click back into place.
    If you removed the knob, replace it and you're done.
    suum quique
    Bikini- that was it. THanks a TON. I guess the shop guy didn't know what the hell he was talking about.
    Old man on a bike
    If you had just read the manual you wouldn't have had to talk to a shop guy...
    suum quique
    The sections I read showed me how to take the caliper apart- from that, it looked like something came undone or snapped.... oh well. Now I have an extra brake caliper in case anything happens.
    Time to get a new shop guy. Seriously. And when someone on the internet tells you that nothing is wrong and to read the manual, what can it hurt? The fact is, an LBS mechanic has NOT seen everything there is to see in bikes, and there will always be at least 1000 people on the internet who have seen your exact problem. Why ask in an internet forum at all if your just going to blow off the answers?
    For things like bikes, the cumulative internet knowledge is extensive. Use it wisely, learn, and you wont need the LBS any more.
    FYI- I didn't just blow it off.... I just didn't ask until after I took it to the shop and had it replaced. Unfortunately, I had to get it fixed quickly so I could ride on Wednesday. Oh well, lesson learned.
    And yes, I'll be taking my stuff to another shop from now on. Its too bad because I know the guy who owns it- but that's the second thing they've screwed up this year.
    Quote Originally Posted by smmokan
    Build up some good Karma, and take that section of manual into the shop and let the owner and the technician know that they missed something. It may help the next person that comes in to that shop with a similar problem. They won't know they were wrong unless you tell them (in a nice way of course).
    Reputation: cleo's Avatar
    Quote Originally Posted by Bikinfoolferlife View Post
    Just an FYI... five years later I ran into the same problem. The above didn't work for me exactly, but did let me know I hadn't broken the brake. I put a wrench in between the pressure feet and pulling the brake lever did the trick!
    Thanks MTBR!
    May 2014
    My outer adjustment knob is stuck. Just used the caliper for a couple of weeks commuting. Worked fine until suddenly stopped turning. When I try to force it, it looks like the plastic will brake.
    I took the caliper off, tried playing around with anything I could think of with no effect. Any ideas?
    B A N N E D
    Quote Originally Posted by Pasi View Post
    Post some photos.
    You could try prying the red adjuster dial off to see if the foot screw is the problem.
    Overhaul / Service Guides
    Older model BB7's/BBDB's: http://my-sport.spb.ru/manual_1/ball...ce%20guide.pdf
    Later model BB7's: http://cdn.sram.com/sites/default/fi...al_english.pdf
    May 2014
    I'll be able to post photos in a few hours, after work. The caliper says 2014, its an ebay purchase.
    May 2014
    @ home... what should i take a photo of? the brake looks normal on the outside...
    B A N N E D
    Explain exactly what did to the brake?
    May 2014
    Installed it, but was not satisfied, so after a week or something, I understood, and decided to install it again, by first attaching to the rotor, then tightening bolts. I did the rear, and realized that the outer adjuster didnt work.
    I installed it by using the inner adjuster, then loosening. It works perfectly. I've been commuting with the tools in my pocket, but starting to feel safe. Like this I just dont have the pad adjustment?
    When I realized it was stuck I took of the caliper, opened the wires, then put it back on.
    B A N N E D
    Is the foot screw properly positioned in the slot that's in the middle of red adjuster dial?
    Have you turned the adjuster dial at all or has it always been seized?
    Reputation: watts888's Avatar
    Oct 2012
    If you're having a hard time turning the larger back side adjustment knob with your fingers, it's normal (at least on the ebay one's I've gone) I have to use a torx key to turn it.
    If it's the outside one (small knob by the swing-arm), does it turn in either dirrection, or completely locked up? Does it turn at all when the caliper is off the bike or the wheel is removed (ie. no rotor in the caliper)?
    May 2014
    it used to turn easily, and it was obvious when it reached either end. I took it off, and its the same with or with out rotor. If I force it a bit, it looks like the pin will rip the plastic. And yeah its not the torx side, that side is still working, and how I adjusted it for my commute.
    Reputation: newfangled's Avatar
    I've found this pretty helpful in the past:
    <iframe width="560" height="315" src="//www.youtube.com/embed/rppADOgTNSM" frameborder="0" allowfullscreen></iframe>
    <iframe width="560" height="315" src="//www.youtube.com/embed/hEsa-iWakdc" frameborder="0" allowfullscreen></iframe>
    I will warn that his instructions at the end (2:50 of the second video) to just "pop" the piston back in often doesn't work for me. Sometimes it just will not budge, and you have to rotate the piston around until it finds a weird sweetspot. So I prefer going one step further, and actually taking the lever arm off (which also lets you get to the bearings to add grease).
    B A N N E D
    Take the adjuster dial off with a screwdriver and try turning the foot screw with a pair of pliers.
    The adjuster dial turns the foot screw which adjusts the pad.
    The following manual shows how to take the adjuster dial off.
    May 2014
    Looking at the diagram in the first link to the manual gives me hope in a sense, but with so many pieces it seems pretty scary to take apart
    *edit: didnt notice the new comments. I will try to take it apart after work. So the red dial can just be forced out with a screw driver?
    May 2014
    This is awsome, but part of opening the caliper is turning the little dial. And its stuck.
    Quote Originally Posted by newfangled View Post
    Yeah, sorry. The video is really good in general, but what you should do to start is take the arm off, and the video doesn't show that.
    But it's pretty easy:
    https://www.sram.com/sites/default/f...l_bb7__bb5.pdf
    Once you do those steps (be careful because when you take the arm off there are 3 loose ball bearings), you can follow the video and take out the piston on the other side. And that will give you access to everything.
