    Aug 2013
    MTBr Users: Caliper, Rotor & Pad Combonation List
    So, list up your Caliper, Rotor and Pad combinations and tell MTBr if your combination screams in wet conditions, or if it does not. Please only list up if you keep up maintenance and have had the brakes re-installed multiple times by self or shop.
    If you like, you can also include a small summary of the conditions that lead to the brakes screaming and how you cured it. That is, if they have a tendency to scream when wet.
    I will create a list and keep it updated with links in the list to each participants post. The list will be comprised of;
    Quiet Brake Combos:
    Caliper, Rotor & Pad Combos That Don't Scream When Wet
    Screaming Brake Combos:
    Caliper, Rotor & Pad Combos That Scream When Wet
    pdxmark: 2013 MTN_BB7; sintered-metallic pads; G2 CleanSweep
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    Aug 2013
    Screamers
    I'll start:
    Brake Combination:
    Started screaming when the wet season started. Faced pads and rotor and imbedded as per instructions on Pinkbike Tech Article. After a couple of rides to work and back brakes started screaming again. Cleaning rotor and pads with alcohol stops the noise for a little while, but noise has always comes back.
    The only likely thing I can think of is contaminants(oil and other chemicals) in the rain water from the ground that splashes up onto the rotor, or, these pads and/or rotor(s) are poo! I think it's more the pads.
    Edit: Next payday I'll order some Discobrakes 'Black ceramics', imbed and repost.
    Edit2:On another registrants advice, I washed my caliper, pads and rotor with brake cleaner, wipe clean, than re-imbed. I did just that. I got out in the rain and the breaks were squealing/screaming loudly. So I pumped really hard and than braked hard, did this several times and my brakes did not scream on the way to work.
    Well, after work, get the bike into the rain and they start screaming again. So again, pump really hard and hard brake, several times... Screaming gone for the whole ride home.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    you will be extremely hard pressed to find a combo, or any for that matter that don't when wet.
    Aug 2013
    I'm starting to think that the big ass holes in my G2Cleansweeps are collecting oily ground water and causing the brakes to scream until I burn the water/contaminants off with hard braking.
  1. Rotor Q-Rings users question
    By osokolo in forum XC Racing and Training
    Last Post: 10-28-2014, 07:17 PM
  2. Need MTBR users help!
    By aaronpass in forum Passion
    Last Post: 07-31-2012, 09:34 AM
  3. Ok to use BB7 caliper with pre-worn BB5 rotor ?
    By David C in forum Brake Time
    Last Post: 01-17-2012, 10:09 PM
  4. Caliper and rotor are too close together
    By DarkFly3r in forum Brake Time
    Last Post: 04-30-2011, 05:43 PM
  5. Need rotor advice from Marta SL/storm rotor users
    By Shuteye in forum Brake Time
    Last Post: 02-14-2011, 02:58 PM
