Results 1 to 2 of 2
    Authority is dead!
    Reputation: Lucky13's Avatar
    Most efficient bleeding?
    What would be the most efficient method of bleeding XT 4pot? Every time I bleed, I need to pump the brake after; are there any ways to avoid this process?
    For the love of Oi
    Rent a house at Attitash
    Reputation: Jaji's Avatar
    i have heard that you should set the adjustment screw for lever distance all the way in before bleeding your XT's. then after bleeding, set the lever distance to what you want. other than not getting air into the lines, im not sure there are any 'methods' as far as an efficient bleed goes.
  1. Replies: 2
    Last Post: 04-16-2004, 05:54 PM
  2. tips/tricks for bleeding xt discs
    By fl jay in forum Brake Time
    Last Post: 04-14-2004, 10:02 AM
  3. Marta SL bleeding - what am I doing wrong?
    By AnoBlur in forum Brake Time
    Last Post: 03-28-2004, 06:52 PM
  4. Need help bleeding my Magura Marta SLs
    Last Post: 02-29-2004, 07:31 PM
  5. Grimeca: bleeding and adapters
    By Lucky13 in forum Brake Time
    Last Post: 02-11-2004, 08:37 PM
