Results 1 to 23 of 23
    more rotor painting
    just another project to kill some time
    remove rotors with a t25 torx
    clean with rubbing alcohol, prep is key
    mask off brake track and mounting holes
    oops old can of white paint is no good
    time for a trip, got some safety yellow
    elaborate weather guard and wire setup. spray light coats and alternate strokes for each coat. i wait 5 mins between each coat. light spots are ok just remember light coats to avoid drips
    drying, will add a few more coats later
    remove tape, i was more concerned with masking off the backside of the mounting holes because i did not want any interference with the mounting.
    inspecting the goods
    put the screws back in
    finished
    You should have probably put small corks in the rotor holes because you can see the outline of square tape. But other than that its pretty cool.
    2009 Trek 6700D
    Bearded highlighter
    pretty cool, i didn't mask the mounting holes and did not have any issues reinstalling the rotors
    Please make it stop.
    Why oh Why
    Doctor
    Dec 2008
    Quote Originally Posted by reptilezs
    ..should be interesting to see how they look after they get hot.
    jeff
    I'm doing my new 203mm BB7s tomorrow with Krylon X-Metals Anodized Red.
    ghey
    Old man on a bike
    I guess I'm glad they're not white...although I've got to say even white would look better.
    suum quique
    I wasn't sure about the yellow but after seeing the rest of your bike the colour rally suits it and looks stunning well done.
    powered by ibuprofen
    Reputation: ecoast's Avatar
    Nov 2008
    me likey
    I've also made some rotor painting for my girlfriend's bike.
    If I will not find a skewer with corresponding color, I will paint it also
    Recreational Racer
    Reputation: Jvan_wert's Avatar
    Why?
    “Let me 'splain. No, there is too much. Let me sum up.”
    Quote Originally Posted by noodletips
    jeff
    Use engine paint or gunkote rather than krylon exterior enamel
    Reputation: 2clue's Avatar
    the paint hold up perfectly fine even after long descents where the the rotors heat up. I used paint meant for the rims of cars and its held up good for the past couple of months
    *Contents Under Pressure
    Reputation: hotfeat1227's Avatar
    that red looks hot
    There is an art, or rather, a knack to flying. The knack lies in learning how to throw yourself at the ground and miss.
    Riding makes me happy!
    Reputation: Bo55Diesel's Avatar
    I have the same frame and I love it! I've never seen a seat mount like that - what is it called?
    I might go the other direction with my rotors and paint them black. I plan to black out my entire bike at some point and I might as well start with the rotors.
    Nice work!
    You guys and gals make me want to ride off-road.
    Check out my Twitter: http://twitter.com/Bohamilton
    Reputation: nagatahawk's Avatar
    factory paint
    I just installed a Rockshox Pike 454 with 20 mm thru axle. so I had to built a new front wheel. I also replace the rotor to fit the new hub. The Frame KHS AM2000, wheels Mavic D 321 and rotor XTR 8 " center lock are all factory painted semi flat gun metal grey.
    offroader
    Dec 2008
    Quote Originally Posted by Jerk_Chicken
    I'm with you on this one Jerk
    Reputation: eurospek's Avatar
    More like a waste of time if you ask me.
    konahonzo
    It's not my bag, but it doesn't hurt my feelings when other folks do it
    ♥ ς╥33£
    Reputation: longcat's Avatar
    I'm like 0.0% impressed, Iiked your frame tho, looks like steel, steel we like.
    Quote Originally Posted by Curmy
    Carbon is a fad.
    Quote Originally Posted by robicycle
    Just lube your ass with asscream and ride for how long you want.
    offroader
    Dec 2008
    They kind remind me of the plastic spinners folks used to put on their honda civic to give it some bling.
