Results 1 to 3 of 3
    mbtr member
    Reputation: scottzg's Avatar
    Are monoblock calipers really stiffer?
    It seems like a couple steel bolts would be stronger than the aluminum they replaced.
    Seems like 2 piece calipers would really just be a cost saving measure.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    More carbon fiber please!
    Many of the lighter brakes use a one-piece caliper. It's probably quicker to machine halves than to set up and do multiple machining operations on a single part. But you can use lighter bolts to hold two-piece calipers together if you wish.
    Meh.
    Reputation: XSL_WiLL's Avatar
    I believe monoblock calipers are stiffer per gram than a 2-piece caliper.
    I guess there's also not that joint for it to spread apart or flex at.
    More material in the bridge or a thicker bridge will lend to a stiffer caliper.
