Thread: Mono Mini Help
    Mono Mini Help
    So I have a set of hope mono mini's like so: http://www.pricepoint.com/detail/129...-Hydraulic.htm
    does anyone make an adapter so that you can run bigger rotors then what came with them? The front works fine with a 203mm, but the rear is like some 4" hope rotor that sucks. Anyone??
    ...idios...
    Reputation: SteveUK's Avatar
    Yes, Hope do a 20mm adaptor. Any bike shop that deals with Hope will be able to order one for you. Or try ebay, sometimes they show up on there and there are other companies doing similar things. You could just Google '20mm disc adaptor cycle', it's bound to show something useful...
    Diogenes
    so right now I have a 140mm rotor on the rear and the actual caliper bolts onto the frame, I want to be able to run a 160, or even 185 or 205. I'm not finding an adapter that looks like the one I need.
    have a link?
    ...idios...
    Go here >>>> Hope USA, scroll down the left to Brake Mounts.
    Google is your friend...you can cut and paste these;
    hope 20mm adaptor
    hope 40mm adaptor
    If you don't have a Hope dealer near you, email Hope direct and they'll either supply you or tell you where you can get what you need.
    Diogenes
