Results 1 to 3 of 3
    mono mini - 180mm or 160mm front rotor?
    i've pretty much decided on the mono mini for my next purchase and was wondering if i should go 180mm or 160mm up front. i guess for that matter should i go 140mm or 160mm in the rear. they will be going on a giant NRS air with a marz marathon sl.
    i'm 190 with gear/camelback and mainly XC. i like to let it loose on the long downhill fire roads though.
    thx
    carlos
    Reputation: magpie's Avatar
    Quote Originally Posted by venga venga venga
    thx
    carlos
    Definetly go with 180/160 at your weight, they modulate better than any other brake I've tried
    Dave
    always go big. 180/160 is the minimum. you might even want to check out the mono m4's , if you are not a weight weenie.
  1. Hope Mono Mini weights....
    By 1speed_Mike in forum Weight Weenies
    Last Post: 12-18-2007, 07:04 PM
  2. Hope Mini disc rotor thickness?
    By discolite in forum Brake Time
    Last Post: 07-10-2004, 01:41 AM
  3. My new HOPE MINI MONO (or MONO MINI ?)
    By pintense in forum Intense
    Last Post: 03-09-2004, 04:48 PM
  4. Replies: 2
    Last Post: 03-09-2004, 04:06 PM
  5. F&R Mono MIni 4 less'n $328.23?
    By Zizzle to the Tizzle in forum Where are the Best Deals?
    Last Post: 02-09-2004, 07:11 PM
