The question I have is wether or not I can mix and match brake calipers with different brand rotors? Specificly Avid Mechanical with Hayes Rotor.
Also if you can run 180mm rotors with 185mm calipers? If not if the Hayes 203mm will work with the 8" Avid rotors?
