Results 1 to 2 of 2
Thread: Missing Bolts?
    Reputation: Goddy's Avatar
    Nov 2003
    New question here. Missing Bolts?
    I was just curious about the dangers of riding while knowing you are missing one of the 6 bolts that holds the rotor onto your rear hub? It stems from a long story, but in short I stripped the bolt, and drilled it out in order to remove the rotor, I replaced the rotor but now the hub doesn't accept the bolt all the way.
    I have a new wheel coming this week but still wanted to ride in the meantime, no problem or advise against?
    Saratoga Mountain Bike Association - www.saratogamtb.org
    "Tri" sticker. Translation: "One Less Good Bike Handler."
    Just make sure the other 5 bolts are good and tight. You should be fine.
    Quote Originally Posted by Goddy
  1. bolts bolts bolts
    By gic in forum Weight Weenies
    Last Post: 08-26-2004, 11:56 AM
  2. alloy stem bolts and brake boss bolts??
    By carbnjunkie in forum Weight Weenies
    Last Post: 06-24-2004, 10:50 AM
  3. Replies: 14
    Last Post: 04-23-2004, 02:35 PM
  4. help with ti bolts please!!!
    By carlos in forum Weight Weenies
    Last Post: 01-30-2004, 06:05 PM
