Results 1 to 5 of 5
    Mini mono pros - split lever for easy install?
    Hi, im going to get the Hope Mini Mono Pros soon and was wondering if they have a split lever or am i going to have to take off my grips and shifters and bar-ends to install? These grips are going to be a b!tch to get off, hoping i wont have to Thanks.
    ...idios...
    Reputation: SteveUK's Avatar
    It's split, no worries...
    Meh.
    Reputation: XSL_WiLL's Avatar
    I do believe that the Mono Mini uses a split clamp design (two bolts tighten from the bottom). Though grips shouldn't be that hard to get off. Use compressed air. Or use a dull flathead, slip it under the grips, spray some windex between the grip and the bar, work it around, twist, and presto, the grip is off.
    Thanks guys
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    The Mini Monos, Mono M4's and Ti6's all use the same lever with a split clamp.
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
