    Jul 2013
    mineral oil leaking from deore m596 lever
    Hi all
    Just hoping that some one can point me In the right direction!
    I swaped my elixir 7s fo my old deores due to the braking feel and unreliability of the avids.
    Now lv bled the brakes the rear is really spongy and is leaking from the the lever (from under the resivour cap). And can not for the life of me make it stop.
    Please help?
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    When you bled the brakes, did you push the lever forward after you closed the bleed screw to let air out of the line? Push the lever forward and tap the line and the reservoir body. Also, the reservoir just has a seal that holds the fluid in, so it is probably just overfilled. There is no real pressure in the reservoir, unless maybe air is creeping in from the line and messing things up. So do a bleed again and remember to open the line to the reservoir by pushing the lever forward.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Jul 2013
    Quote Originally Posted by Prophet Julio View Post
    Thanks for that...I did flick the lever a few times to get any trapped air out (im guessing that tip was naff).
    Ill let you know how it goes tomorrow.
    Reputation: Bigb2000's Avatar
    May 2013
    I had the same issue. An o-ring was missing from the master cylinder. Strange it didn't start leaking until after a couple of months.
  1. Replies: 5
    Last Post: 04-22-2013, 09:24 AM
  2. Avid Elixir 3 or Deore M596
    By bravo4588 in forum Brake Time
    Last Post: 12-27-2012, 05:57 PM
  3. Shimano Deore M596 for a clydesdale?
    By Nubster in forum Brake Time
    Last Post: 07-24-2012, 05:26 PM
  4. Replies: 5
    Last Post: 02-09-2012, 04:09 PM
  5. Replies: 5
    Last Post: 02-05-2012, 07:09 PM
