Results 1 to 5 of 5
    mechanical brake pad change, frustration
    brake pads needed to be changed on my tektro novela brakes. Figured it would be easy enough and after all the adjustments in the world (and even getting a new rear rotor that was bent), the rotors are rubbing on the inside brake pad.
    Anyone know what bike shops usually charge to get these adjusted? Starting to wonder if my frame is bent slightly cause when I try adjustments on the back, the pads don't lay flat against the rotor. They either touch only at the top or bottom.
    Reputation: Bald_Ben's Avatar
    May 2005
    Usually it's about $10-15. If you're nice to your mechanic, he'll probably tell you the specifics of the problem or maybe even let you watch. Hopefully there's nothing more than adjustment needed, but that'd be hard to diagnose over the tubes.
    "A thing is right when it tends to perserve the integrity, stability, and beauty of the biotic community. It is wrong when it tends otherwise." - Aldo Leopold
    thanks. I will find out tomorrow. If its something major, Ill have to decide whether I wanna buy a frame and move stuff over or buy a whole new bike...
    If the tabs are not properly aligned a shop may use this Park Tool Co. Disc Brake Mount Facing (IS type) with DT-1
    took the bike in this morning to my LBS and took them no longer than 20 min and the bike ran like new. Best $16 I ever spent. Took it to the normal trail I ride all the time and it was crazy how much easier it was.
    Not sure what I did wrong but I sure don't know how to adjust brakes very well.....
  1. Replies: 9
    Last Post: 07-03-2014, 12:48 PM
  2. Replies: 8
    Last Post: 03-09-2013, 12:48 AM
  3. Need Mechanical Brake Suggestions
    By Duntov1967 in forum Brake Time
    Last Post: 02-02-2012, 06:07 PM
  4. formula oro lever change frustration
    By the_Alaskan in forum Brake Time
    Last Post: 12-21-2011, 06:02 PM
  5. Mechanical Brake rub question
    By TheDoc46 in forum Beginner's Corner
    Last Post: 06-11-2011, 07:40 PM
