Results 1 to 3 of 3
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Maximum width on Hope Floating Rotors
    Anyone got a max. width measurement on the Hope floaters? I'm trying to figure out if I can make em' fit or not . . . looking at my current set-up, I have an extra 2-3mm between the rotor and post . . . it'd be tight for sure. I'd like to avoid any grinding if possible.
    Oct 2007
    Quote Originally Posted by OO7
    I don't know the exact width of the floating rotors... But
    I have a boxxer 2010, hope pro2 hubs
    Saint calipers, hope saw floating rotors....
    And I had to slightly grind one end of the adapter, and you may even need to grind the caliper.... Because the rivets tend to touch the caliper/adaptor area (almost sure is the lower bolt area).... Anyway it's pretty much nothing what I had to grind...
    If i remember right, my rotors were 4mm (might be just a hair more or less) at the spider and the eyelets/rivets (whatever they are called).
