Results 1 to 5 of 5
    Maximum Front rotor size?
    Does anyone know the maximum recommended front rotor size for Rockshox Tullio with 30mm stanchions?
    I've got an opportunity to upgrade to a hub with a 20mm front axle. The hub has a 200mm rotor installed. I've read that some have gotten in to trouble using a front rotor that is too large.
    The rotor will be used on a 2002 Specialized Enduro Pro FSR with Hayes Mag disc brakes.
    Thanks In Advance,
    Uni
    Reputation: Kiwiplague's Avatar
    If it is a Rockshox Pyslo fork with tullio axle, then it can take up to 210mm disc size, so you should be fine. Duke forks too. Anything below those i.e. SID/Judy/Pilot, was 165mm.
    Thanks Kiwiplague,
    How do you know the maximum rotor size?
    LightJunction.com
    Reputation: lightjunction's Avatar
    It's probably in your manual somewhere. But I usually just call the manufacturer. SRAM has a number listed on their site for tech support.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    Used to have a Duke fork years ago, and got the info from Rockshox.
