Results 1 to 3 of 3
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    mavic v brake rim for disc build
    Are there draw backs of using a Mavic, 217, or 517 to build up a disc wheelset?
    thanks for your time.
    bikerbert
    Reputation: bikerbert's Avatar
    There was an article in Velonews that said the higher the number of a Mavic MTB rim, the stronger/more durable it is.
    Have you tried the CrossRide? I've had them since May, and I like them quite a bit.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Sometimes the last two digits refers to the width of the rim. Sometimes wider rims are more durable. Mavic changes around their numbers a lot.
    You can lace up a rim-brake rim to disc hubs just fine. You'll just have the added weight of a braking surface.
