Results 1 to 6 of 6
    Welcome Turner Homers!
    Reputation: el Turtlehead's Avatar
    Marta's pistons are sticky! Help!
    Yeah, I've done the ole tire lever routine to the pistons on my Marta and have had some success but it's only been temporary: So, alas, the inboard piston on my front brake refuses to retract properly, drags and howls incessantly. Before I send the brake ack in to Magura, anyone have any suggestions other than the tire lever method?
    thanks
    Shylock, MCM# .45359kg
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    One suggestion...
    Do the ole' tire lever thing again, holding one piston back while letting the other extend.
    Only this time dab a thin layer of Maggie brake fluid on the piston then push it back in again. Cycle the piston a few times & repeat on the other side.
    If that doesn't work then me thinks you need to contact Magura. They're pretty good with emails:
    lonnie@magurausa.com OR
    jimi@magurausa.com
    How old are the brakes? The first ones did have some problems with the piston seals being too hard and not allowing the pistons to retract properly but this was usually only during cold weather.
    about a year old.
    They came with the magura blood already in their veins, so I believe they were made after that problem with the pistons. could be wrong , though.
    Quote Originally Posted by skinl19
    If they have the blue fluid then they are later models, the earliest ones had the green fluid which in itself could cause some stickiness.
    Daniel the Dog
    I spent a year wrestling with mine....
    Quote Originally Posted by Shylock
    thanks
    Finally, I sent them to Magura. They have excellent customer service. I had a warranty issue with them. They sent me a new brake no questions asked.
    So, don't knock yourself out, call Magura. Unlike what I did initially...
    Jaybo
  1. Sticky Thread
    By CrashTheDOG in forum Site Feedback/Issues
    Last Post: 07-19-2004, 05:52 PM
  2. EBC Gold and Marta's
    By skinl19 in forum Brake Time
    Last Post: 03-26-2004, 01:45 PM
  3. Magura Marta's with SRAM X.9 trigger shifters
    By MINImtnbiker in forum Brake Time
    Last Post: 03-23-2004, 03:24 PM
  4. can i use shimano adaptors with martas........
    By maynard in forum Brake Time
    Last Post: 01-15-2004, 04:36 PM
  5. What about Sticky threads?
    By MMcG in forum Site Feedback/Issues
    Last Post: 01-01-2004, 11:01 AM
