Results 1 to 3 of 3
    marta - sticky lever anyone?
    Hi Magura experts. Has anybody encountered this problem: rear brake lever stays depressed after braking?
    Inrideo est vita
    Reputation: SSteel's Avatar
    Quote Originally Posted by obaby
    Clean the lever, invert it and apply a bit of brake fluid to the piston. Cycle the lever a few times. That should eliminate the problem.
    Happened to me on 2 different brake levers (Martas), this fixed the problem permanently both times.
    Canadian distribution: X-Fusion Shox, Rand Momentum lube and Canadian Shield fenders.
    TheRide.ca
    Facebook
    It's working now!
    Quote Originally Posted by SSteel
    Thanks ssteel for the suggestion.
    I didn't have any of the Magura oil so I went to the friendly folks at Sunshine who helped me out. Before going I cleaned the area with a spray of rubbing alcohol. After we applied lube to the lever piston, the action did get better, but then another trick was tried that really freed everything up; the lever was "wagged" up and down (perpendicular to the normal motion). Whatever the culprit was, it works perfectly now.
  1. Magura Marta SL lever problem
    By mihurka in forum Brake Time
    Last Post: 08-17-2008, 08:33 AM
  2. Slow Marta lever return.
    By MightySchmoePong in forum Brake Time
    Last Post: 11-08-2004, 07:32 AM
  3. Magura Marta lever (and hose) wanted
    By Juan Solo in forum Brake Time
    Last Post: 09-10-2004, 05:19 AM
  4. Quick breakin technique for sticky Marta pistons?
    By Gnarlygig in forum Brake Time
    Last Post: 06-25-2004, 10:09 AM
  5. Marta SL bleeding - what am I doing wrong?
    By AnoBlur in forum Brake Time
    Last Post: 03-28-2004, 06:52 PM
