Results 1 to 32 of 32
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Marta SL's impressive in power. Same as Louise/FR...
    I have a LOT of Magura brakes now, all Louise and Louise FR. A guy on the Turner board just mentioned wanting to unload some Marta SL brakes and I picked them up (lightly used for $125 for the pair no less ) to give em a whirl. I took my Louise brakes off the 5-Spot, and bolted the Martas on. I went ahead and left the Louise rotors and adapters in place to compare apples to apples. The fork has a #15 adapter and a 190mm rotor in front. The rear bolts right up with no adapter and I am running 160mm rotor. I went out to bed the brakes in this afternoon (no real ride; went skate skiing earlier) and was surprised that they came up to basically exactly the same power as the Louises. I generally run Endurance pads, and the Martas may have Performance installed (forgot to look), though the two pads generally generate similar power in my experience.
    The rotors which came with the Martas are blue on the brake track and look kinda cooked. The calipers seem similar in weight to the Louises so I am guessing the heavier rotors Louise brakes use will make the diff in dealing with heat build-up.
    The surprising thing is that the rotor/pad clearance seems greater on the Martas than the Louises. Rub is easier to eliminate. Who woulda thunk it?
    My video techniques can be found in this thread.
    Daniel the Dog
    I agree....
    Quote Originally Posted by tscheezy
    The only reason the Louise FR I am riding now are more powerful is because I have 7" rotors on both ends. I also cannot tune out the rub on the front of my Louise FRs. I also think the Marta has better modulation. What do you think?
    A recent British mountain bike magazine rated the Marta as a better brake than the Louise FR. They stated the Marta has better modulation with nearly as much power. They stated the Louise FR are grabby at times. I'm not sure I agree with that but I don't think the Hayes Mags are off and on brakes.
    Killer deal!
    Jaybo
    I don't notice a difference in modulation yet. The lever is shorter on the Marta and this gives you a little less leverage. The master cylinder guts look the same, so I think the two systems push the same volume of fluid for a given lever throw. The calipers also seem to use the same pistons, so you would get the same piston movement for that lever throw. The pad's friction material is the same I am guessing, and offers the same area of contact with the rotors. Basically the Martas are the same mechanically as the Louises, just in a lighter package. The diff in heat resistance is probably the rotors. Even the 160mm rotors the Louise come with have a much more substantial brake track compared to the Marta 160's and so probably more heat absorption/cooling capacity. Even the fluid reservoir in the master cylinder looks to be similar in volume.
    The carbon lever scares me a little, and I may take them apart to reduce the small amount of lever slop where the lever blade's pin pushes on the master cylinder. Otherwise most of the performance seems to come from the rotor size.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Am curious to hear your thoughts on Marta in reagards to fade & pump on long descents. As Jimi once explained it to me, the reservoir on Marta is not as large as Louise so there is less room for expansion when things heat up.
    Quote Originally Posted by The Squeaky Wheel
    I doubt I will ever be able to answer that. I probably don't have a long enough sustained descent here at home to put the brakes through a real heat fade test, and when I travel I take the 6-Pack.
    If the brakes heated up and the fluid expanded beyond the reservoir's capacity to take the extra fluid, the caliper pistons would simply not retract fully and the pads would start dragging on the rotor (what you called pump?). I don't know how many ml of fluid the Louises can accept compared to the Martas, but just eyeballing the inside of the reservoirs, it actually looks similar. The membrane which seperates the fluid from the atmosphere is thicker on the Martas I think. That may eat some expansion room.
    Fade would be dependent on the ability of the caliper and rotor to conduct heat away from the pad/rotor interface and I don't think the fluid would take any real part in this regardless of the reservoir's ability to take expanding fluid. If the fluid circulated (acted as a coolant) somehow it could make a difference. The Marta caliper has a lower mass so is able to absorb less heat before leading to fluid expansion so may be given to both fade and pump, but as I said I don't think I will ever hit that point.
    according to Jude from Magura, the rotor does make a big difference, but it also has a decent weight difference... so using the Marta with the Louise rotors erases some (but not all) of the weight savings of the Marta.
    As far as tuning out rotor rub on the Louise, have you gotten in there with a thin file gauge and tried to reset the pistons? Also, are you sure the rotor is dead straight? Morningstar makes some killer tools for truing up larger diameter rotors. Also, if you're working in the stand and there's a little rub left, take the bike for a good ride- I've started a ride with some rotor rubbing and by the time I'm halfway done, the problem has taken care of itself.
    I wasn't complaining about rub, just saying the Martas offer a tiny bit more pad retraction it appears.
    Daniel the Dog
    Quote Originally Posted by Jordan
    You are absolutely right about the rubbing taking care of itself halfway through the ride. You are also right about the rotor having a millimeter or two of of wobble to it. Anyway, to get back on thread, the Magura brake is finicky with a constant need for some level of love to work at its peak. Not a complaint. It just is what it is. I do think Tscheezy is right about the Magura having the same power with equal rotors. But, the Louise FR does have better levers in my opinion (seem a bit beefier).
    Jaybo
    Daniel the Dog
    I might have to look at the Marta
    My Louise FR's pretty much rub in the fron before every ride. I take 'em off, reset the pads, and go ride. They usually run fairly free by the end of the ride. Ride is over and they rub again. It is so much fun to do this before every ride. If the Marta's stop this pain in the butt process, I'm game. I want to ride, not screw with a brake system before every ride. My Hayes never rubbed unless they were covered in mud. I'm whining...I'll admit. I don't have a terminal disease, maybe a bad attitude, but certainly want nearly maintenance free brakes. I apologize ahead of time to the Magura homers on this site but I really don't want a MCM number Just kidding..cheap shot.
    Jaybo
    PS they do work well once they quit rubbing. Oh, they do make a vibrating noise 4 times or so during a ride. Big deal. I just want the rubbing to stop. Make it stop! Laughing.
    Bodhisattva
    Question Jaybo.
    You state that your front rubs before every ride. Is this after removing your front wheel to load it onto a rack ?
    i definitely don't have that problem before every ride, but when i do, i can usually fix it without taking the wheel or the brake off to mess with the pads. if you're using 180mm or larger rotors, try this: with a glove on (or a really clean hand) find the spot in the rotor that's rubbing, and bend it gently toward the pad it's rubbing on, then grab the brake hard a few times with the rotor in that position. that almost always works, and i know it's not as good as the brake being maintenance free, but once you get used to it, it only takes 30 seconds and you're ready to ride.
    Daniel the Dog
    Question Jaybo.
    I reset the pistons when I do that; however, you could be on to something because my QRs are never completely consistantly tightened. This changes the position of the wheel a touch. What I'm struggling is how to find a happy medium for these brakes require perfect alignment to run quiet and not rub. With Hayes, Avid, or other slot systems, you just loosen the bolts and either eye the caliper and rotor or just loosen the bolt and tighten to align. I prefer this design. Some hate slot systems.
    I need to true the rotor also. It wobbles probably 1-2mm. I'll see how bad I can warp it with a monkey wrench .
    By the way, I'll admit, I have a bone to pick with Magura because my Marta's were such a pain. Nonetheless, they flat works as well as anything except Shimano (sorry Magura).
    Jaybo
    Daniel the Dog
    Good tip
    I will give it a shot.
    Jaybo
    Bodhisattva
    Jaybo,
    I suspect operator error, not a brake defect.
    You need quick nuts
    http://www.1upusa.com/quicknuts.html
    Daniel the Dog
    I agree....
    Jaybo,
    You need quick nuts
    But, this is the same response I got on my Marta's a couple years ago. I finally, after a year, sent the rear one to Magura, and it was a bad brake. They replaced it. I appreciate the link to quick nuts; however, I'm a bit uneasy about the name of them
    Jaybo
    Bodhisattva
    Kidding aside, sounds like the problem you're experiencing is from tightening your front QR at varying tensions. The quicknut is $3.99 and is a quick & easy fix.
    Daniel the Dog
    I'm almost talked into plain old XTs
    I played with those Magura's for 3 hours tonight. Still rub! Urg! The rear one has never rubbed one second. So, I can't believe it is my setup. I have changed a couple flats too. The pads in the front don't spread enough to allow the rotor to run drag free. F 'em!
    Mike at Universal told me to go XT. Idiot proof with the best levers and modulation I have ever tried. I'm obivously not smart enough for Magura.
    Jaybo
    That's ironic
    When I was working at a shop, I saw probably more XT discs than anything except Hayes 9's, but I installed quite a few Maguras as well. In my experience, I almost always had trouble getting XT's to run drag fee- I had the exact problem you're having with Maguras... not enough space between the pads. I even talked people into Maguras when they couldn't get their XT's to run right, and no one ended up complaining. But you're experience is your experience, so I'd say go XT if you've had good luck with them. Also, don't forget about El Caminos. Same drag free performance as with Hayes Mags, but better modulation.
    The only real dragging issues I have had with Maggies was if I did a bleed with well-worn pads and ended up overfilling the system. The pistons would then not retract enough when new pads were installed. Using the yellow travel spacer during bleeds fixes this (not doing this was a goof on my part). I have Maguras on 4 bikes and none of them rub.
    Daniel the Dog
    I was impulsive....
    I bought a new pair of Magura Marta SLs from Performance. It sounds like you got a killer deal but I got 'em for $315. Not bad. I will probably sell 'em on Ebay and make a few bucks and later use the points to buy something else. Any reason to keep the Marta SLs and sell the FRs? Any difference between them besides a small amount of weight and power?
    I will let some oil out and see if that helps.
    Jaybo
    To get oil out, push the pistons in as far as you want them to go, then rotate the lever's reservoir to be horizontal and loosen the tiny torx bolts on the reservoir. If there is extra oil in the system, it will ooze out from below the res cap. You can then immediately snug the cap back on and not bleed or anything.
    I don't know yet if the Martas offer anything over the Louises. I was just surprised at how similar they were, actually.
    I-S
    I-S is offline
    Magurified
    Reputation: I-S's Avatar
    When using the standard wavy rotor, how much weight difference is there between louise and marta though?
    Magura's numbers bear out what you say... the piston sizes are the same in the marta and louise systems, and magura claim 6.2ms^2 deceleration for 160mm louise vs 6.0ms^2 for marta/sl.
    Since the piston sizes are the same, that suggests you could use the marta caliper with the louise lever (or vice versa). That would get the reservoir volume back (if indeed that is a difference), but obviously the weight saving involved in changing from a louise caliper to a marta caliper is pretty small if everything else remains the same... it might give this greater pad clearance though.
    The Marta master cylinders, lines, and calipers taken together are about 50g lighter than the Louises per brake. The rotors are lighter too, but I am not counting those.
    Daniel the Dog
    Mine no longer drag :)
    I finally said screw it and bleed them myself. The LBS did it twice and was overfilling 'em. The right amount of oil created a bigger gap, so my rotor doesn't rub anymore. I also found a guy at another LBS who is skilled at working on them. He gave me some tips.
    I'm done with LBS mechanics. I can do 90% of my own wrenching but some stuff I can't do: facing tabs. I don't have the tool. I thought the LBS could handle the job. Wrong!
    I might sell the Marta's to the homers on the Turner board for just what I paid for them. I need to buy an ad first.
    Jaybo
    PS One tip I learned is to slightly loosen the resevior lid, push the pads apart until they are back all the way, and then tighten the lid up. It removes the last bit of air and puts the right amount of oil in the system. Worked for me.
    Quote Originally Posted by Jaybo
    Good for you. My bikes have not seen the inside of a bike shop in many, many years. With practice you can do a better job than most shop rats out there. Face it, it's your bike, so you just care more. Buying some specialized tools like headset presses and learning how to use them is an investment in your autonomy.
    Reputation: Arek's Avatar
    A few questions on Marta SL's
    Sorry if I'm hijacking this thread in any way. I'm almost ready to pull the trigger on these for my Spider, but I have a few questions and was hoping some of Marta SL owners in this thread could chime in and help me make my decision.
    I currently run Avid mechs with XT 160mm rotors (SD7 levers, Flak Jacket cables), and they work good, although I miss the feel of a hydraulic system. I weigh about 210lbs+ suited up to ride, and stopping power seems to be sufficient with 160mm rotors. Not throw-me-over-the-bars powerful, but I never craved this kind of power anyway.
    I think I have them adjusted pretty good (had them for 4 years now, on different bikes), but the modulation just doesn't seem as good as a hydraulic system. I have hydros on my other bike, so I know the difference in feel. The Avids feel just... well, mechanical. Plus, I wouldn't mind having a lighter system either.
    So my question is - should I expect Marta SLs (with 160mm rotors) to be at least as powerful - or more - as my current setup, or chances are I won't see much difference, as far as the power goes? The last thing I want is to be surprised to find out that after shelling out the money my Avids had more raw stopping power...
    Another thing that worries me is what I've read in numerous reviews (here on mtbr), that report a problem with air entering the system if you turn the bike upside down, and hence necessity of a bleed? I think there's a few mentions of need for frequent bleeds in general. Anyone of you guys had this problem? That doesn't sound to me like something that should be happening on a top-dollar brake system...
    Any input would be appreciated! Thanks in advance guys.
    Arek
    Quote Originally Posted by Arek
    Arek
    My experience so far is that Martas are significantly more powerful than Hayes HFX-9. I have had several sets of Hayes and even though I never thought I'd need more power and modulation, the Martas literally blows them away. YMMV as I'm 150#, but I do ride hard on the brakes.
    Regarding setup, I didn't have any particular problem. Actually, I'm completely rub-free for the first time in years... A small amount of rub here and there never bothered me with the Hayes, but with the Martas, there is simply none.
    They aren't too noisy either.
    Lastly, I managed to cut the lines to length without having to bleed the brakes. Neither did I crash afterward, it worked Can't do that with DOT fluid. Also supposedly mineral oil won't attract water as much hence they shouldn't require bleeding for a long time if all goes well.
    We'll see with time how they hold up but so far I'm pleased.
    HTH,
    Maurice
    Thanks Maurice! How about others? Tscheezy?
    Arek
    I ride Avid Mechs on my townie bike with 6" rotors. In that rotor size, I give the power edge to the Avids over the Martas, easily. In fact, I really don't think any of my Maguras with 6" rotors in front is quite sufficient, much less for a 210# guy like you (I'm 180). Get the 180mm front for the Martas and you will probably be very happy. The Maggies come in long arm and short arm versions. To make the front caliper 160mm, they use the short arm style. To run a 180mm rotor up front without needing an adapter, get the long arm style (like all the brakes use in the rear).
    I have never had the flip the bike and bleed issue, but then I am pretty careful when I bleed and don't flip my bikes often. I lay them down regularly, but don't turn them over and start squeezing levers.
    [QUOTE=tscheezy]To run a 180mm rotor up front without needing an adapter, get the long arm style (like all the brakes use in the rear).[QUOTE]
    Thanks for your imput. I should mention here, that I have a Minute 2 on my bike, so my front caliper would be post mount. Does it come in the "long arm" style for post mount as well? And, something that I've been wondering too - when and if I decide to get a different fork (so far I'm very happy with the Minute), is there a post-mount-to-IS adapter? I couldn't find the answer to this on Magura's site, but maybe there's another way I'd have to go to get 180mm rotor on the front anyway - I found a pic on their site showing a std. IS mount (short lower leg) caliper used with an adaptor to post mount with a 180mm disc. Does that pretty much tell me that unless I go with 160mm rotor, I can't get a post mount caliper to work with my fork? There would be nothing wrong with it if that's true, as I would need another adaptor for post mount caliper to go 180mm anyway, the only problem that I forsee in the future is this: I end up with a short leg IS caliper when I decide to use it on a IS mount fork, focing me to either use a 160mm rotor, or to use another adaptor (#16) for 180mm set up.
    I guess there's no way around it, really... I think with any possible combination I will end up having to use an adaptor. I was hoping - when I still thought I could stay with 160mm rotor up front - I could get a Manitou style caliper, and use a post-to-IS adapter for a IS mount fork in the future... Or maybe there's a way to do it with only an adaptor for one fork using an 180mm rotor I'm not seeing?
    Arek
    EDIT: In case my question is confusing - I think it is, I just confused myself just re-reading my post - what I meant to say at the end is that I was hoping I'd have to use an adapter only for one type of fork mount - preferably for when I move to IS fork. But I guess there's no way to avoid an adapter for both forks if goung with 180mm rotor. Which sucks a bit, as I was hoping to use a clean look post mount caliper mount now, not to mention additional weight.
    "El Whatever"
    Reputation: Warp's Avatar
    Thanks for the insight, Tscheezy.
    From the Magura Cult Homepage and somewhere else, I had read that the Martas have less oil volume at the reservoir and some special cautions must be taken because of this when bleeding them (or was it for pre-2002 Martas??). They were supposed to be less fade resistant and more sensitive to pad thickness. But again, I'm too lazy to check it right now. I'll take a look at it tomorrow.
    Anyway... Being so similar in weight and performance, I'd take the cheaper Louises any day as an upgrade to my Julies (as soon as the wife forgets about the 'Blade ).
    If I remember correctly, master and slave cylinder sizes are equal on both brakes and should be interchangeable. That would make a Louise with a carbon lever
    Check my Site
    "El Whatever"
    Quote Originally Posted by Warp2003
    OK, I was reading a Maggie Catalog this morning and came to realize Martas and Louises share the sam caliper pistons size, but the Master Cylinder on Martas is smaller (10mm) as opposed to the 12mm Louises.
    This would make the Martas actually more powerful than Louises if anything else equal... There's gotta be something else that makes the Loiuses slightly more powerful or to equal Martas.
    Check my Site
