Results 1 to 8 of 8
    zeebot
    Reputation: Spookykinkajou's Avatar
    marta sl squeal '04
    they squeal really bad when wet but silent again once they dry. is this going to change with age? i just used them today for my first ride in wet/muddy conditions...they work great all the time just sounds like i'm killing a pig when squeezing them after a healthy dose of water/mud.
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Are the tabs on the frame and fork faced?
    Quote Originally Posted by Spookykinkajou
    That seems to help some.
    gfy
    Brake Squel
    There is a new product from Moterex that stops disk brake squel. It is a copper compound you apply once. I have never used it. My brakes squel when wet also. I live in California so there is not enough wet conditions to worry about it. Good luck.
    I have had good luck stopping squealling by removing the rotors and sanding the brake surface with a orbital sander and fine sandpaper. I have also sanded the pads lightly and cleaned everything with alchohol.
    Wayno
    Sublime Absurdity
    Reputation: sodade's Avatar
    What does "facing" mean?
    Wave upon wave of demented avengers
    March cheerfully out of obscurity into the dream
    There's no app for this.
    Reputation: JimC.'s Avatar
    wet brakes squeal. Period...
    I've have/had 4/ 5 sets brands: Magura (Louise & Gustav) Hayes Comps; Hope M4's; Shimano 525's. My wife runs Shimano mechanicals.
    Whenever you get them wet, expect noise.
    Jim
    zeebot
    Quote Originally Posted by JimC.
    Jim
    i suppose i was riding in ridiculously wet conditions. since that day i posted they've been perfectly fine with only a light squeal occasionally during very heavy braking for extended periods of time. like the brakes(don't love them yet) but i think once i get the kinks worked out they will serve me well.
    one other issue i'll address in a different post since it's unrelated to squealing.
    facing means
    you use a tool to make sure the interface between your brake calipers and the bike frame/fork tabs is perfectly flat. It's a hand tool that strips paint and metal to ensure the mount of your system is perfect. It's not now, trust me.
    I can't find the Gnannomat one I've used, here's some pix of the Hope tool. Your LBS should have one., If not, they are short a very necessary tool they should have.
    http://www.hopetech.com/products/tool_02.htm
    Jim MCM #11
  1. 04 Psylo SL on a 04 Stumpy FSR?
    By frank4 in forum Specialized
    Last Post: 04-07-2004, 06:39 AM
  2. 04 Marzocchi Z1 FR SL
    By duc135 in forum Shocks and Suspension
    Last Post: 03-26-2004, 09:14 AM
  3. '03 vs. '04 Iron Horse Hollowpoints, Changes
    By Speedub.Nate in forum Bike and Frame discussion
    Last Post: 03-22-2004, 11:02 AM
  4. Marta Rotor More Likely to Squeal than Regular Wavy?
    By Loco Louie in forum Brake Time
    Last Post: 03-18-2004, 01:04 PM
  5. Hayes Mag Plus VS. Magura Marta SL
    By mbikertim in forum Brake Time
    Last Post: 03-12-2004, 08:00 AM
