The Riddler
Marta SL paired with XO Grip Shifts...Setup Question
I was wondering if anyone could lend some advice as to the best way to set up the XO grip shifts and marta sl disc brake levers next to each other. I have heard that a little adjustment needs to be made in terms of location and position on the bars. I'd appreciate any help!
Just set them up to line up with your hands correctly. Adjust as needed. Try about a 50 degree angle.
(aka SS_MB-7)
Here are some pics of my Racer-X 100's set-up:
FWIW, the pics were taken when my bike was brand-new, with uncut FSA bars. After some extensive riding and racing time, I'm going to take off ~1" per end. This will move the entire cockpit inward by 1" per side. At this point, I'm going to leave the lock-on grips at their stock length. If I find the cockpit is too cramped, then I'll take the ends of the lock-ons. As it stands, my RX's brake position mirrors my SS' brake position.
The Riddler
thanks for the pics. that helps.
Remember when you mount this combo not to run the barrel adjuster on the XO's right next to the master cylinder. It's easy during setup to forget this as you run them tight together.
I always hated that set up on my bike....
I could never reach the Marta's levers well with the XO setup. I would dump the XO stuff and get the X9 triggers. Much better in every way except weight.
Jay
By AnoBlur in forum Brake Time
Last Post: 03-28-2004, 06:52 PM
By dawgcatching in forum Weight Weenies
Last Post: 03-25-2004, 04:00 PM
- You may not post replies
- You may not edit your posts
Forum Rules
