Results 1 to 2 of 2
    Mar 2005
    Marta SL with CODA rotor?
    i have a 2000 F2000 SL volvo cannondale team bike, and it has coda disc brakes on it. im switching to a marta SL, but would like to keep my wheelset. my current wheelset is 4 hole, and of course the marta is 6 hole. i was wondering if i could keep my current wheelset and run the coda rotor. as long as it doesnt rub the outer body of the marta caliper, i dont see any reason i cant.
    can anyone help me out?
    if this wont work, i was going to laser cut some custom 4 hole rotors like the marta SL's, but only with 4 holes. make them out of Ti or 400 series stainless.
    please help, thanks
    as long as the rotor is 160mm and the brake surface is close to the same ist fine.The marta rotor is 2.0mm wide a lot of other rotors are 1.8 mm wide you need to replace the pads a little earlier if you use a thinner rotor to prevent the pistons from coming out too far.
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. Where's the best deal for Marta SL brakes?
    By Mtbric in forum Where are the Best Deals?
    Last Post: 02-23-2005, 02:00 PM
  3. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  4. Coda Expert Brakes used to work well...
    By Edderd in forum Cannondale
    Last Post: 08-30-2004, 03:19 PM
  5. Will Avid Mech work with Coda 4 bolt rotors?
    By Edderd in forum Brake Time
    Last Post: 06-06-2004, 02:44 AM
