Results 1 to 5 of 5
    Marta set up help
    I just switched my wheel set out. Now the rotor rubs the caliper. Do I shim the rotor off the hub or the caliper out towards the hub? Do they make shims for the caliper bolts, by magura or universal?
    Reputation: OldHouseMan's Avatar
    Shim the caliper, not the rotor. Universal Cycles has them.
    I only ride bikes to fill the time when I'm not skiing.
    thanks alot called local shop and got hooked up.
    More carbon fiber please!
    You can use the simple trick of grabbing some electrical crimp-on connector ends with eyelets. Cut off the eyelets and use the eyelets for shims. You can stack them if necessary. Or, find the right washers/shims if you can. Shim the calipers if you are only running one wheelset. If you run a couple wheelsets (and each has their own rotors, such as one race set and one heavier set...) then shim the rotors to fit one caliper location.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    The only reason to shim the rotors, is because of the post mount calipers. Man, what a drag(literally) that can be!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
