Results 1 to 8 of 8
    Live Free or Ride!
    Reputation: GiantMartin's Avatar
    Marta Rotors w/ Avid Brakes
    Would Magura Marta (Wave) Rotors work with Avid Juicy Ultimate brakes or even Formula The One's? Has anyone tried it?
    2007 Giant Anthem 1
    2009 Giant XTC 0
    Zipper
    Reputation: rbtcha's Avatar
    Nov 2007
    I'm running the Hope Gothic upgrade rotor on both Avid Juicy's and BB7's
    Here's a link - https://www.bti-usa.com/public/item/HT19203 - to check them out
    You should be able to run Just about any solid rotor with them
    Zipper aka Rob
    magura rotors are 2.0 mm vs 1.5-1.7 for others. That may be an issue, but pricepoint is selling the magura rotors for like $23 right now. So, if it doesnt work out, you arent out much.
    Lead by my Lefty............... right down the trail, no brakes.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    RARE Avid Rotors!
    Avid made wavy rotors too, and they looked exactly like Marta SL. Elguapogrande on eBay sells them. They each weigh 100 grams and I paid only $30 for the pair, and they work BETTER than the Avid Cleansweep G2/G3 rotors. Too bad Avid no longer makes them, because GalferUSA(edit) tried to sue Avid over copyright infringement.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    ups and downs
    The wavy rotor is actually a Galfer international patent.
    Quote Originally Posted by rockyuphill
    Does that mean it's actually a Magura patent made by Avid?
    Quote Originally Posted by rbtcha
    did you do this for noise issues? if so, did the hope rotors eliminate the noise?
    www.derbyrims.com
    Reputation: derby's Avatar
    Formula rotors are the same thickness as the Marta SL (Galfer) wave rotors. I'm running the Marta SL rotors with Oro's. Most silent rotors I've ever run, even when wet after a couple revs. And they add a little more power over the stock rotors. They are wearing very long and evenly without any concave. I expect these will get over twice the wear of Hayes and more than Avid rotors.
