Results 1 to 6 of 6
    Reputation: glenzx's Avatar
    Marta piston travel question
    I've abused my Marta's this seaons pretty significantly, and they have performed incredibly! I only bled them at initial hose length/set-up, and after 1-2 days thereafter, had 'em dialed. Lately, I've noticed that the front caliper seems to exhibit less piston-retraction. Just wondering if besides a cleab & bleed if there are other maintenence issues I should consider..... like is there a need to remove the piston(s) and clean the bores? I'd bet not, considering they still look pretty clean and it'd be an excellent contamination oppurtunity!
    I just can't believ how powerful these brakes are for how light they are. I bomb wicked descents pretty aggressively, and they offer pretty amazing modulation & power, hot or cold.
    "It's better to regret something you HAVE done, than something you haven't..." -
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Could be that some grit has gotten stuck on the piston and is preventing proper retraction.
    Here's what I would do:
    1- try reactuating the piston. Remove the pads and with a plastic tire lever hold the unaffected piston flush against the caliper body while you actuate the lever. This will force the affected piston to extend. Don't over extend it or you might get fluid lock (I had this happen once & it sucked). Push it back in with a plastic lever & repeat a few times.
    If that doesn't work then...
    2- Recatuate the piston but this time clean the piston with an alcohol soaked q-tip before pushing it back in. You can then apply a very thin layer of Magura blood to the piston before pushing it back in. Don't put on too much or it will attract dirt. Just wipe it on with a q-tip or your finger (Magura doesn't officially endorse this, but they do it anyway).
    Quote Originally Posted by The Squeaky Wheel
    Excellent advice! I was thinking about doing the 'pump the affected piston out' a little and see if it looked dirty there..... good note about putting a little "blood" around the piston before easing it back in too.... thanks again!
    Bodhisattva
    tis nuttin'
    Magoooooraaaahhhhhh
    The Riddler
    Reputation: Kaparzo's Avatar
    Try White Lightening Clean Streak, it works even better!
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by Kaparzo
    Yes, this was recommended to me by Shimano Canada when I had issues with my XTR's sticky piston syndrome. It worked only temporarily.
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
  1. Question about neg travel on Super T
    By The Dude in forum Downhill - Freeride
    Last Post: 08-29-2004, 07:41 PM
  2. psylo travel question
    By coolatt in forum Shocks and Suspension
    Last Post: 06-17-2004, 09:21 PM
  3. Marta piston problem, or design?
    By Gnarlygig in forum Brake Time
    Last Post: 06-17-2004, 12:24 PM
  4. Technical question on shock length vs travel...
    By BanzaiRider in forum Shocks and Suspension
    Last Post: 05-14-2004, 01:34 PM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
