Results 1 to 3 of 3
Thread: MARTA Piston
    May 2005
    MARTA Piston
    I just had a piston pop out of my Marta's as i was bleeding them. Anyone else have this problem? I suppose I should put a few of these in here just to make it.....annoying
    Reputation: VT Mike's Avatar
    Quote Originally Posted by we_todd_did_wun
    Yeah, I just did that a few weeks ago. You need to have something between the pistons, like cardboard, or an old set of pads, or both (I always take the pads out to make sure no brake fluid gets on them). I hadn't bled my brakes in a while, and forgot about that part. I got it back in without too much trouble, but it sucked having to bleed the brake all over again.
    Do It Yourself
    Reputation: Homebrew's Avatar
    Quote Originally Posted by VT Mike
    You are supposed to remove the pads and insert the back side of the yellow travel block in caliper while bleeding to prevent this from happening. You can probably pop it back in without damaging the seals. Good luck!
    Long Live Long Rides
  1. Replies: 3
    Last Post: 04-26-2005, 08:21 AM
  2. 2nd Hayes piston not working at all
    By bluronthetrails in forum Brake Time
    Last Post: 12-20-2004, 10:08 PM
  3. Marta piston travel question
    By glenzx in forum Brake Time
    Last Post: 09-29-2004, 06:45 AM
  4. Marta piston problem, or design?
    By Gnarlygig in forum Brake Time
    Last Post: 06-17-2004, 12:24 PM
  5. Please HELP with HFX-9 !piston problem
    By tatarovsky in forum General Discussion
    Last Post: 02-25-2004, 09:36 AM
