    marta brake line switch and bleed questions
    I just bought a set of Magura marta brakes off Ebay for cheap but the brake lines are reversed. Short hose for rear brake. The original owner must of had the brakes reversed. Anyways, I know you can shorten the hoses without bleeding, but can you switch lines without bleeding?
    If I do need to bleed can I use my Avid bleed kit and adapter? Of course I would have to buy the correct fluid.
    Reputation: k1lluaA's Avatar
    you cant mount martas on either side? like the levers aren't reversible?
    2008 Kona Caldera
    "Today I saw my own son use a bicycle as a weapon....
    I seriously thought he was going to rape me"
    Quote Originally Posted by k1lluaA
    I only meant that he had the lever mounted so his left hand worked the rear brake.
    B A N N E D
    You might find some useful info on your brakes here.
